SRAM continues to evolve their products and they’ve made some updates to their 2016 product offerings. Learn more about the Guide Ultimate brakes and CenterLine X rotors inside.
The SRAM Guide brake family introduced a new standard for mountain bike brakes through rigorous design and testing, and has been proven at the highest levels of competition in the Enduro World Series and with downhill World Cup wins.
With its completely new, 4-piston S4 caliper, SwingLink lever cam, and carbon lever blade, the 360-gram Guide Ultimate stands alone as the new leader in its class. It has been engineered to be light and powerful, with superior heat management capabilities, which give you better, more consistent, more reliable braking.
The new caliper design also incorporates a re-designed seal and aluminum piston interface for ease of setup and improved consistency, while Bleeding Edge technology makes bleeding Guide Ultimate a quick and easy task.
CENTERLINE X ROTORS | LIGHT, QUIET, SMOOTH |AVAILABLE: July 2015
CenterLine X rotors are the lighter-weight version of SRAM’s quiet, smooth and robust CenterLine rotors, featuring a two-piece design with an alloy center and steel brake track.
GUIDE ULTIMATE | AVAILABLE: May 2015
FOLLOW THE LEADER
The SRAM Guide brake family introduced a new standard for mountain bike brakes through rigorous design and testing, and has been proven at the highest levels of competition in the Enduro World Series and with downhill World Cup wins. With its completely new, 4-piston S4 caliper, SwingLink lever cam, and
carbon lever blade, the 360-gram Guide Ultimate stands alone as the new leader in its class. It has been engineered to be light and powerful, with superior heat management capabilities, which give you better, more consistent, more reliable braking. The new caliper design also incorporates a re-designed seal and aluminum piston interface for ease of setup and improved consistency, while
WHAT’S NEW:
S4 CALIPER
NEW SEALS, PISTONS AND GLAND GEOMETRY
The S4 caliper features completely redesigned seals, pistons and gland geometry that ensure consistent piston rollback. This translates into:
Easy setup: less time required to achieve proper caliper alignment and pad retraction for drag-free performance.
Consistency: precise piston rollback guarantees a constant lever feel and contact point in all situations.
HEAT SHIELD
Aluminum heat shields breaks the thermal connection between the pad and caliper body. Reduces caliper fluid temperature by about 20C even in the most extreme testing conditions.Patent pending.
PISTON INSULATOR
Insulator integrated in the piston.
Phenolic pad interface: phenolic compound reduces heat transfer from the pads to the piston thus reducing fluid operating temperature. Aluminum seal interface: consistent finish and reduced seal wear.
OPEN PAD POCKET
More air flow through the caliper to reduce heat:
Pad pocket is 2mm wider than the standard Guide caliper.
Pad pocket length is increased to expose full length of brake pads to air flow.
BLEEDING EDGE TECHNOLOGY
New bleed porting and fluid path make it easier to push fluid through the caliper for quick and easy bleeding. Dedicated bleed adapter for the S4 caliper plugs into the bleed port and seals the system to minimize air contamination and fluid loss.
Pricing:
