If you’ve got an e.thirteen TRS style crankset, e*thirteen has got some new sing rings they’ve been working on that will be available soon in a range of sizes. Learn a little bit more about the Guidering M chainrings inside.
These ring will be available in a 28-38t size. With an influx of people running XX1 or single ring setups, the need to run a smaller front chainring on some occasions are popping up. With a conventional chainring spider you can only go so low without running into clearance issues with the spider.
This chainring replaces the spider as it bolts directly to the crank arm itself. I suspect we’ll see more crank manufacturers doing similar things to future cranks to accommodate this sort of setup. If you’ve got SRAM cranks, you can check out MRP’s bling ring option as well.
e*thirteen is currently trying out a few finishes to pick the best option for their customers.
See more details on the e.thriteen products at http://bythehive.com/e-thirteen/
