2013 MRP Debuts New Chainguides – G3 , 1x, AMG, MICR
8/31/2012 : sicklines
For 2013, MRP has revamped their chainguide range.  Check them out inside in addition to their new bling direct-mount chainring that interfaces directly with most SRAM cranks.
MRP have expanded their chainguide options for 2013.  The AMG (All Mountain Guide) is aimed at riders who want some bash protection and chain retation but have a Shadow + Shimano or Sram Clutch style derailleur.
, 2013 MRP Debuts New Chainguides – G3 , 1x, AMG, MICR
MRP AMG (All Mountain Guide)
The 1x gets a new upper nylon guide that carries over across most all of the new MRP range.  It also has a deadening device to reduce chain slap noise where the chain often hits at the pivot point on the upper slider.
MRP 1x
The MICRO guide (MICR) offers a bash guard option for riders in a slimmed setup.  The modular design gives users the option to remove the bash while still retaining the chainguide’s upper and lower functionality.  Ideal for smaller chainrings like the new SRAM XX1 setup.
MRP MICRO
Optimized for 28-32t chainrings.  Available in ISCG, ISCG-05, and BB mount options.  Compatible with 8-11speed single ring drivetrains.
The MRP G3 is a new guide for MRP this year.
MRP G3
It has got a carbon backplate option as well for those looking for a light setup.
MRP G3 Carbon
It is available in a Mini (32-36t) or Mega (36-40t). ISCG, ISCG05, and BB mount.  Compatible with 8-11speed drivetrains in black or white.
MRP G3 - Backplate
The G3 guide comes with both a lower pulley style roller as well as a replaceable slider style clip that can be used as well.  Both are included with the guide so users can pick to run the slider or the pulley with their system.
G3 lower guide & integrated skid
The G3 scissors apart and the lower roller and bash are integrated into one piece.  This should make for some quick removal for cleaning and service. The lower section is still polycarbonate but they’ve gone to a nylon upper slider as they felt this helps with stiffness and better durability across solvents.
MRP G3 pivots out of the way
In addition to chainguides, MRP also has relased their Bling Direct Mount Chainrings that you see on all of the cranks above.  They’re compatible with SRAM X9 / X0 and Truvativ AKA cranks.  Available in a variety of sizes from 28t-36t (even sizes).  Compatible with 8-11 speed drivetrains.  Weight claims between 53-94g so certainly quite a bit of weights saving considering no spider is necessary.
Be sure to check out additional Eurobike 2012 coverage on our site.
