New riding gear gets riders excited to ride and for 2013 Alpinestars has got a few new pieces that should get you excited. They’ve got a new neck-brace compatible armor and various other riding gear pieces. Check it out inside.
Lightweight, with ergonomically profiled protection in strategic zones, the Comp Pro has a breathable mesh construction for unsurpassed comfort. Engineered for a precision fit, the top can be worn under a jersey and will accommodate the Bionic Neck Support (BNS), enabling the creation of an advanced upper body protection system.
Protection and performance
Removable back protector is CE-certified, ensuring it has been independently tested and assessed to meet the strict impact and safety performance standards required by the European Union.
Slim-profiled shoulder protectors are lightweight and provide superior impact resistance. Protectors are removable.
Soft chest and side padding is reinforced with 8mm impact foam for added impact absorption and comfort.
Removable upper chest pad enables secure accommodation of BNS.
Short-sleeved styling allows for use with Alpinestars elbow protectors for added upper-body protection.
Comp Pro Short Sleeve Top for BNS
Comfort
Streamlined design for superior body fit which enables top to worn under jersey.
Lightweight, stretchable mesh main construction with breathable padded inserts, includes strategically placed panels to ensure the vest remains well fitted.
Ergonomic back protector follows natural curve of the back.
Integrated kidney belt features soft thin hip straps to eliminate bunching around waist.
Gravity Gloves
Gravity Gloves
Aero Gloves
Aero Gloves
Aero Gloves
Moab Gloves
Moab Gloves
A-Line Jersey Features:
Lycra construction with small vented panels on the sides for improved cooling performance.
Sleek fitting profile offers superior aerodynamic performance.
Fabric stretches in one direction only for enhanced fit and to further improve aerodynamic efficiency.
Ergonomic design allows easy integration with elbow and back protectors.
Long sleeved design.
Silicone printing on lower back keeps jersey in the correct position when tucked inside pants.
A-Line Long Sleeve
A-Line Long Sleeve
A-Line Long Sleeve
A-Line Pants
Rugged, lightweight and ergonomically profiled, the A-line Pants grant the rider superior riding comfort with high levels of ventilation and adjustability. The innovative design allows the fitment of protectors while maintaining a comfortable, well-fitted look.
Ergonomically designed for a close fit and easy integration with knee protectors.
Strong ripstop rear panel for extra durability and abrasion resistance
Lightweight and durable main fabric construction with strategically placed air mesh inserts and stretch panels.
Reduced lining around the waist area for enhanced riding comfort.
Thin, lightweight waist construction.
Vented panels on the upper thighs and lower leg.
New 2-way stretch inserts at crotch enhance freedom of movement.
Innovative two-way stretch construction on the back of the leg and knees.
Dual tabbed Velcro® waist adjustment with windowed TPR D-ring adjusters grants a precise, adjustable fit.
Soft, lightweight TPR details.
Discreet front zipper with snap closure ensures secure fitment.
