PUSH Industries has a great reputation when it comes to improving suspesnion components. They’ve gone the extra mile now and have come out with a new rear shock of their own called the Elevensix. Learn more about this Colorado manufactured shock inside.
MSRP $1,200
100% Manufactured in Colorado at PUSH from the finest domestically sourced raw material.
Each unit is hand assembled, vacuum bled, and dyno tested. Built custom to rider specification based on rider weight, riding style, and frame application.
Patent Pending Dual Overhead Valve design offers two completely decoupled ride characteristics that can be toggled between on-the-fly. For the first time riders can have ultra plush and ultra firm suspension characteristics without compromise.
Tool free external adjustments for Low Speed Rebound, Low Speed Compression, and High Speed Compression.
Parabolic Low Speed Needle design for both compression and rebound eliminates the “gap” found in production MTB shock external adjustment.
Exclusive HyperCo Ultra Light Suspension Spring available in 25lb/in increments. Made from High Tensile spring alloy and featuring Optimum Body Diameter technology eliminating spring deflection and body wear.
Next generation Digressive Damping characteristic from compression valves provides incredible traction and control while allowing for through travel on square impacts.
High Volume Oil and Nitrogen Reservoir for fade-free performance.
Built using premium Maxima rear shock fluids.
Exclusive 360 degree spring capture and bump stop cup eliminates extrusion of bumper under extreme bottoming loads and ensures proper spring alignment.
