Dive in to learn about the new 2022 Devinci Spartan High Pivot (HP). Constructed from carbon fiber this bike has a number of things riders will want to learn about. Details below from Devinci on their new 160mm travel weapon.
There’s a new standard for speed. Our long-travel enduro weapon brings Enduro World Serie pace to everything you ride, with plenty of room for a water bottle.
Right away, you’ll notice the thrust and stability of a rearward axle path. Pair that with a 160mm Split Pivot design that’s fully active under braking and you’ll experience time-warping levels of control. For those about to blast, Spartan HP is the rocket ship you’ve been waiting for. Hope you brought goggles.
The new Spartan High Pivot has taken a lot of work and Devinci has sent some behind the scenes testing that you should also check out to see how this carbon beauty evolved.
Combining a high-pivot layout with our Split-Pivot platform ef- effectively separates acceleration and braking forces for a buttery smooth ride with hyperactive small bump compliance, in all situations. The rearward axle path increases traction and stability the harder you push it and podium-crushing pedal stroke efficiency makes this bike unbelievably fast.
Modern trail bike geometry featuring a longer reach and slacker head angle for confidently tackling technical sections, while a steeper seat tube angle helps you motor up the climbs.
Action Photos: Sven Martin
Still Photos: Andy Vathis
