Intense sent over some details on their M16 Expert Build that is now available.
Introducing the Expert Edition M16 Carbon Downhill Bike. Built with a carefully chosen spec to deliver the performance of a legendary M bike at an unprecedented value. The Expert Edition features the same geometry as the Factory and Pro models, a carbon fiber monocoque mainframe, 157 x 12mm rear wheel spacing and is carefully spec’d with the best parts and accessories available in the targeting price range.
Standard Carbon Front & Rear Triangles. Monocoque UD Carbon Construction
Front Suspension: Fox Performance Elite 40 Float, 27.5″, 20mm
Rear Suspension: Fox Performance Elite DHX2, 214-240mm Travel
Custom Carbon Protectives at bottom bracket and chain stays, Mud Guard.
See the build specs and more at : http://www.intensecycles.com/bikes/m16c#expert
Frame:
M16 275 Monocoque UD Carbon Front and Rear Triangle 275″ DH Frameset, ISCG 05 Mount, w/ 157 x12 mm spacing, 215 -240 mm travel
Front suspension:
FOX Performance Elite 40 FLOAT, 27.5″, 200 MM
Rear suspension:
FOX Performance Elite COIL DHX2
Hubs:
32 Hole Intense Tuned, 148x 12 mm BOOST; 110 x 20mm Front Hub; 157 x 12mm Rear Hub Shimano Driver, 6-Bolt
Rims:
Sun Helix TR29 Rims, 275″, Tubeless Ready
Spokes:
DT Swiss Champion
Tires:
Maxxis Minion, 27.5 X 2.5″
Shifters:
Shimano Zee, 10 speed
Rear derailleur:
Crank:
Shimano Zee
Cassette:
Shimano CS-HG50-10, 11-36T, 10 speed
Chain:
KMC 10 speed
Chain Guide:
E13 LG1
Saddle:
WTB Volt Sport
Seatpost:
Intense Recon, 300 x 31.6mm
Handlebar/ Stem
Renthal Fatbar Lite DH 20mm x 780 mm
Renthal INTEGRA II Direct Mount 45MM
Headset:
Cane Creek, 40, alloy cartridge, 25 mm of spacers
Brakeset:
Shimano Zee, 203 mm front and rear
Grips:
Intense Dual Density Lock-On
