Last night Shimano held their official launch of the new M9000 XTR components. Available in a trail or race trim they’ve done a lot of work refining the iconic XTR brand. Pricing is still TBD.
Shimano Defines a New Rhythm for Race and Trail Riders with New XTR M9000
Mountain Bike Components and Wheels
IRVINE, Calif. (April 12, 2014) — Shimano today introduced new XTR M9000, its most advanced XTR mountain bike components and wheels to date. With this totally new XTR line available in both Race and Trail “Rider Tuned” product families, Shimano leverages its 22 years of engineering leadership producing the industry’s highest performing mountain bike component group.
Inspired by the versatility and capability of today’s riders and the terrain they tackle, M9000 offers refined and tested solutions engineered for the way they ride.
Drivetrain System: “Rhythm and range” define the 11-speed drivetrain Shimano’s unrivalled legacy in producing bicycle drivetrains is evident with the XTR M9000’s most notable rider benefit: ensuring pedaling rhythm. New XTR M9000 provides range and ensures rhythm for diverse riding styles and terrain to create smooth, harmonic pedalling – the ultimate goal of a drivetrain. The XTR M9000 drivetrain system maintains riders’ rhythm thanks to meticulously selected close step gearing configurations of the cassette and crank.
• FC-M9000: XTR FC-M9000 Race and FC-M9020 Trail cranks are modular, creating a Rider Tuned platform whereby single and double chain rings can be used on the same crank arm. XTR FC-M9000 crank sets debut the most advanced mountain bike chain rings ever produced that utilize combined titanium, carbon and aluminium materials.
Dedicated XTR 1x chain rings debut proprietary chain ring retention technology in a tooth profile that eliminates the need for chain retention devices.
XTR FC-M9000 Race cranks have a narrower 158mm Q-factor and utilize a lighter and stiffer 3D hollow bonded structure on the non-drive arm.
XTR FC-M9020 Trail cranks are available in single, double and triple chaining configurations on the cold forged more durable, standard 168mm Q-factor crank arms.
Chain ring configurations: Single (30T, 32T, 34T, 36T), double (34-24T, 36-26T, 38-28T), triple (40-30-22T).
The chainring is a complex design that utilizes titanium to improve chain retention, longevity and durability
CS-M9000: Rhythm is the essence of smooth power transfer and proper gear step is the key to maintaining rhythm over varied terrain. The XTR CS-M9000 11-speed 11-40T cassette is the widest range cassette Shimano has ever produced and also it’s most balanced. Thanks to its “rhythm step” progression, it maintains calculated, shock-free gear steps from one gear to the next, saving riders energy and helping maintain rhythm on the trail. Key features include:
CN-HG900-11: Shimano introduces its premium new 11-speed chain that delivers overall better performance for mountain bikers. The CN-HG900-11 uses a HG-X11 special asymmetric plate design and Shimano’s new SIL-TEC surface treatment.
XTR Shifting System: the Ultimate stability and response
Shimano systems engineering creates a new level of shifting precision in the M9000 XTR shifting system. With both lighter action and increased stability, Shimano’s M9000 XTR shifting system redefines gear change performance while introducing enhanced ergonomics. XTR M9000 debuts a bold new front derailleur design and approach for larger wheels and longer travel that delivers remarkable shifting performance.
SL-M9000: XTR M9000 offers Shimano’s most responsive mechanical shifting and controlling shifts is easier than ever thanks to a reduction in shift effort by 20 percent. The SL-M9000 shifters feature:
FD-M9000: Shimano’s new FD-M9000 masters front shifting for double and triple crank sets with a new, first-ever Side-Swing front derailleur design that increases shift performance by a staggering 100 percent. Designed specifically with modern trail bikes in mind, Shimano’s XTR FD-M9000 Side-Swing front derailleur provides 15mm of increased tire clearance, while new cable routing dramatically reduces shifting effort.
RD-M9000: With a refined Shadow RD Plus clutch rear derailleur, a new front derailleur structure and a new XTR chain (CN-HG900-11), M9000 offers the most stable drivetrain the industry has ever seen. A new Shadow design optimizes the slant angle, lowering shift effort while improving shifting and driving stability while the derailleur is even lower profile protected further from harm’s way. The new Shadow Plus clutch has a simpler external clutch adjustment, and the derailleur has a wider range of adjustment for easier setup.
Braking System: Rider Tuned XTR Race and Trail brakes
New XTR M9000 hydraulic disc brake systems are also Rider Tuned in Race and Trail versions, as not all riders come down the same mountain at the same speed. Shimano’s legacy of leading brake design stems from its dedicated study of the components of control: heat, power and stiffness. New XTR M9000 brakes offer varying levels of heat control from an insulated piston (glass fiber phenolic) and insulated pad coating that created 10 percent more heat resistance. XTR M9000 brake levers also feature new handlebar-clearing I-spec II mounting.
The XTR M9000 Race brake system has race-tuned power and overall lighter weight thanks to a magnesium caliper and master cylinder as well as a carbon lever blade. The XTR M9020 Trail brake system is trail-tuned for power and stiffness using pre-loaded aluminium caliper and a new SERVO-WAVE lever with a powerful and stiff carbon-alloy structure.
Wheelsets: Shimano goes carbon with XTR Race and Trail wheels
The all-new XTR M9000 wheels mark a serious turning point for Shimano in premium mountain bike wheel sets. They are Shimano’s most advanced mountain bike wheels to date, and also the first featuring carbon laminate rim technology. New XTR M9000 series wheels are even more focused at each end of the spectrum, from ultra-light and durable race wheels to all-mountain tuned trail wheels. All new XTR wheels use 28 butted spokes both front and rear and include a new lightweight bearing and axle system.
HB/FH-M9010: A cosmetic update, lighter rear axle system and a 15mm E-thru axle provide XTR technology at the center of the wheelset.
XTR Pedals: Continuing 25 Years of Shimano SPD
In 2015, Shimano celebrates its pioneering 25-year legacy of Shimano Pedaling Dynamics (SPD). Shimano continues this legacy with both the PD-M9000 and PD- M9020 pedal versions.
