BOS Announces RaRe Idylle Air Fork
5/23/2012 : sicklines
, BOS Announces RaRe Idylle Air Fork
BOS sent through some information on a new RaRe Idylle fork that they’ve developed that uses air instead of a coil. Lighter, same price, as well as low/hi speed compression, rebound, and their hydraulic bottom out. Check it out inside.
BOS Idylle Rare Air Suspension Fork
, BOS Announces RaRe Idylle Air Fork, BOS Announces RaRe Idylle Air Fork, BOS Announces RaRe Idylle Air Fork
Weight decreases, price stays the same
You are certainly impatient to know if the weight loss is significant… 300g less.
Retail price stays the same at 1990 euros.
RaRe means Race Ready
That’s the reason why RaRe is written as a single word, but with two capital “R”. Don’t forget it !
SPECS
Hydraulic fork featuring ..
Open bath cartridge
Air spring
Travel : 200mm
Adjustments :
Hi speed compression
Low speed compression
Rebound
Hydraulic bump stop
Air bleeding screw on top of the right stanchion
Stanchions : aluminum 7050 – ø 36mm,
Machined between the crowns
Lower legs : magnesium
Triple crown : alu 6061 forged + machined.
Steerer : 1”1/8
Axe ø 20 mm.
Postmount IS brake
Claimed Weight : 2850 g
BOS announced their Void Air Shock as well earlier this year that you can also check out.
Visit bosmtb.com to learn more about the BOS suspension range.
