Roval Components has redesigned their Control SL wheels for high level XC/Trail performance. The lightest Control SL Team LTD model weigh in at a scant 1248g with a 29mm rim. Details inside from Roval.
Roval Components announces their new Control SL Team LTD wheelset today and they have a lot of features packed into them to help them perform their best with a solid warranty.
OUR COMMITMENT
We work obsessively to create wheels that are True to Your Ride, but we don’t stop there. As riders, we know that shit happens, so we have your back with a lifetime warranty and
a free no-fault crash replacement policy.
Lifetime Warranty
Roval wheels are warrantied against defects in material and workmanship for lifetime of the customer.
“**it Happens” No Fault Crash Replacement Policy
If a rider damages their Roval product while riding within the first two years of ownership, we’ll replace or repair it for free. This policy applies to all Roval product purchased in the USA, whether it came stock on a bike or was purchased aftermarket. For additional details, check out RovalComponents.com/warranty.
Control Rim
Take a look at the shape of this rim. 29mm inner width, asymmetrical profile, stepped internal
rim bed, 4mm wide flats atop the hookless rim wall. It took SIXTEEN different prototype shapes, and countless hours spent designing, testing, breaking and redesigning, to finally arrive at the
rim you see here. It weighs 358 grams, and is stronger than any rim close to that weight.
There’s just enough vertical compliance engineered in to provide a comfortable, true tracking, long lasting ride. And those wider than
usual flat tops atop the rim walls? It’ll take 22% more force than the competition to pinch-flat tires with these rims. The new Control wheels are packed with features that help bring out the best in your ride, but these rims are the stars of the show.
The new XC/Trail wheelsets from Roval are the Control SL Team LTD. They’re only available in limited numbers as well.
Roval will also be following this Control SL Team LTD launch with a non-limited version in Summer 2020.
The highlights of the wheels can be read bellow so be sure to check out the details to learn what Roval has done to improve their high end wheelsets.
Control SL TEAM LTD ($2650)
This Control SL offers 54t of engagement out of the DT Swiss EXP rear hub. It has a special 29mm (ID) hookless carbon fiber rim and utilizes DT Swiss EXP system with ceramic cartridge bearings and straight pull spokes in a 1248g package
Looking for more details? Be sure to check out the details https://rovalcomponents.com/collections/xc
