Shipping Mid-March e*thirteen is launching their TRS+ 170mm dropper seat post. Details inside from e*thirteen.
e*thirteen 170mm Seatpost: Same Reliable Internals, Longer Travel, Shorter Length.
e*thirteen components
MORE TRAVEL. LESS LENGTH. UPDATED INTERNALS.
When our first seatposts launched in 2016, we dubbed them “RELIABLE. SERVICEABLE. AFFORDABLE.” Being fully mechanical, coil sprung, and well thought out, there was little opportunity for error. This also meant that anybody with a basic set of tools could rebuild the seatpost, should it come to that. To top it off, a mere $279 got you a factory-edition lever, failsafe seatpost, and even the cable and housing.
We’ve used the last two years of sales and testing to only further prove our point and improve our seatpost. Now, our 170mm seatpost is shorter than our 150mm seatpost, more reliable thanks to simplified and re-engineered internals, and still only $279.
LONGER TRAVEL. SHORTER LENGTH.
By simplifying the bushing layout and reducing the length of our cable hanger, we were able to make our 170mm seatpost SHORTER in overall length than our 150mm seatpost.
SIMPLE INTERNALS.
Our 170mm seatpost uses the same fully mechanical, coil sprung, cable-actuated internals that don’t require bleeds, won’t sag out, and can be serviced at home with a basic set of tools.
With less internals, there’s also less to go wrong. To top it off, we’ve updated many of our existing internals to better function in both short and long term.
Don’t want to bleed your seatpost or deal with the reliability issues of many other seatposts on the market? Reach for our fully mechanical, coil sprung TRS+ seatpost.
ONLY $279 MAP.
Need we say more? Save yourself weight, money, and hassle with e*thirteen’s TRS+ 170mm Dropper Post.
PRODUCT SPECS
WEIGHT:
– Seatpost only: 562 grams
– Seatpost w/1x lever: 612 grams
– Seatpost w/1x lever, cable, housing: 693 grams
PRICING
• MAP: $279/ €299
SHIPPING MID-MARCH.
