Silica has updated their T-Ratchet to make it even easier to use. Read more about it inside.
The Lightest Most Compact Multi-Tool With Torque Measurement
Shedding Weight and Improving Accuracy, SILCA Unveils Their Upgraded T-Ratchet + T-Torque Multitools
Monday, October 16, 2017 — INDIANAPOLIS, IN. – SILCA – Re-Introduces their top-selling T-Ratchet + T-Torque multi-tools with an upgraded torque tube making it even easier to use. The T-Ratchet + T-Torque are high ergonomic multi-tools with a torque measuring extender that provides real-time feedback to the torque you are tightening too.
Roughly 70% of damage to high-end carbon components such as seat posts, handlebars and stems happen when making adjustments without using proper torque. This problem is further accentuated by the fact that the majority of adjustments made without torque occur on the roadside or trail.
Weighing in at a mere 30 grams, the Ti-Torque is a featherweight in tool category, transforms a highly delicate maintenance function into an easy, highly portable, and on-the-go accurate adjustment. Equipped with a torque measuring extender that provides real-time feedback, the Ti-Torque beam now has three separate scales on it; 2-6, 3-5 and 4-8. This allows you to more easily see when you’ve reached your desired torque setting.
Other feature highlights include interchangeable magnetic components to convert from a screwdriver to ratcheting T-Handle in seconds, which gives the user the ability to have several tools at once in an extremely small duck waxed canvas carrying case that fits perfectly into a jersey pocket.
Specs:
MSRP – $99 https://silca.cc/pages/t-ratchet-ti-torque
