If you’ve got a 2012-2015 FOX 34 FLOAT and TALAS fork, FOX is offering a $99 upgradge for a limited time for those in the USA. Details inside.
FOX is Offering a Complete Air Spring Upgrade with installation for Its Model Year 2012-2015 34 FLOAT and TALAS Forks for a Limited Time Price Of USD $99 Plus Shipping
Using the same FLOAT air spring technology used in the award-winning 36 fork, FOX is now offering upgrade kits to retrofit 2012-2015 34 forks. The kit replaces the entire air spring assembly, reducing weight and noise while greatly increasing adjustability and performance.
Like the current 36 fork design, the 34 FLOAT Air Spring Upgrade Kit features a positive and negative air spring system, which reduces the force to initiate travel, providing excellent sensitivity and small bump compliance at all pressure settings. The design also allows for internal travel adjustments in 10mm increments and the air spring curve can be tuned using volume spacers.
The 34 FLOAT Air Spring Upgrade Kits are available for FLOAT and TALAS 26″/27.5″ forks at 140mm, 150mm, and 160mm of travel and for FLOAT and TALAS 29″ forks at 120mm, 130mm, 140mm, and 150mm.
This limited time special is available in the United States only and will be honored through August 31, 2016. After that, the kits will retail for $139.00 plus $40.00 for installation.
http://www.ridefox.com/2016/content.php?m=bike&c=airspringupgrade
