Devinci Cycles has an all new 140mm travel Troy mountain bike they’ve been updating recently that we’re excited to tell you about. Check inside for details from Devinci as well as a awesome video with the new Troy featuring Steve Smith!
With the introduction of the Spartan last year it was time for the Troy to get some refinements as well. The Troy maintains some aspects of the earlier version but sees a longer front triangle to give riders more reach (~20mm). This helps their range fit more riders as well as more riders looking to have a longer front end. The Troy is their Trail 27.5″ model that is designed to get you up the hill as well as down. Additional revisions to the updated troy reduce the chainstay length 4mm.
No two mountains are the same. That’s why we storm the globe—from Rockies to Andes and beyond—stoked to caress and conquer every nuance. Devinci’s All-Mountain Troy is the badass tasked to rip that apex terrain. Powered by our Testing is Everything modus, a fifth generation Split-Pivot platform increases bottom-out force based on expert intel from DGR rippers like Stevie Smith.
Clean technical lines from top to bottom thanks to advanced team-inspired geometry. Power up steep climbs with intuitive handling aided by an axed-down 424 mm chainstay. And harness the stability-enhancing benefits of Boost 148 rear-axle spacing for charging coastal backcountry terrain at ultra-high speeds. The All-Mountain Troy scores high marks wherever mountains loom. Point it toward the ranges and roam free.
Geometry
Price for alloy version:
Aluminum Trim Options: Alloy RR, Alloy RS, Alloy SX, Alloy S, Alloy Frameset
Alloy SX
FRAME FEATURES
TAPERED HEAD TUBE
LOWER STAND-OVER HEIGHT
DMC-G
ULTRA-SHORT CHAINSTAYS
SPLIT PIVOT
AXIS & FRG ADJUSTABLE
BOOST 148 STANDARD
INTERNAL CABLE ROUTING
ASYMMETRICAL CONSTRUCTION
27.5 DEDICATED WHEEL SIZE
CUSTOM TUNED REAR SHOCK & ENDURO BEARINGS
See more at www.devinci.com
