2014 Marin Bikes add 27.5 to the lineup | Attack Trail & Mount Vision Carbon
8/20/2013 : sicklines
Marin Bikes have some new offerings for 2014 that we take a look at inside. Aimed at Trail and Enduro athletes these bikes are designed to work for racing as well as trail riding. Both feature a 650b/27.5″ wheel and you can watch the videos to learn more about the differences between the Attack Trail and Mount Vision.
, 2014 Marin Bikes add 27.5 to the lineup | Attack Trail & Mount Vision Carbon
Mount Vision Carbon gets 27.5 wheels
2014 Marin Mount Vision
Mount Vision Models (Carbon XM Pro (pictured), Carbon XM 9, Carbon XM 8, Alloy XM7, Alloy XM6, Carbon WFG XM8)
  • 27.5” Platform
  • IsoTrac Suspension – Is a linkage actuated single pivot suspension system. A new Marin suspension system that replaces heavier and less durable pivot bearings with continuous-fiber carbon-monocoque flex points, which work with a shock linkage to control big-hit capabilities.
  • FRS DownTube Rock Shield
  • Suspension Sag Indicator
  • Stealth Dropper Seatpost Routing
The Mount Vision line is designed and built for epic super-D/enduro racing, where riders need the geometry of a trail bike but the weight and efficiency of a cross-country (XC) bike. These models offer long-travel suspension, with 140mm of fixed travel front and rear, and 27.5-inch wheels. Design features include a build that’s significantly lighter than our Attack Trail bikes, achieved with a simplified suspension system, fixed-travel 32mm chassis forks, and lighter components.
Internal routing on both Attack Trail & Mount Vision - Production version will also include sealing
Mount Vision - flex is designed into the carbon seatstays
Learn more and see the geometry at http://www.marinbikes.com/us/bikes/mountain-bikes/enduro
Attack Trail (27.5)
2014 Marin Attack Trail
Attack Trail Models (QUAD CARBON XT PRO, QUAD CARBON XT8, QUAD CARBON XT9)
  • 27.5” Platform
  • Quad-Link Suspension – An award-winning multi-link suspension design that allows engineers to alter wheel path, shock-leverage ratio, and effective pivot location to manage pedal and terrain forces.
  • 150-160mm travel
The Attack Trail is designed and built for more classic all-mountain riding, with 150-160mm travel full-suspension chassis, and design features including low, slack geometry, short chainstays, smart component selections, and 27.5-inch wheels built with 21mm rims and 2.35-inch tires. The Attack Trail is built for rough backcountry runs.
ISCG Adapters
Linkage
Dropouts and disc brake mounting
Learn more and see the geometry at http://www.marinbikes.com/us/bikes/mountain-bikes/trail/#attack-trail
