Digging the new Saint gruppo
Shimano invited us to check out their 2009 Saint gruppo in Whistler a few weeks ago. We got to check out what the new and hopefully improved gruppo had to offer. See what our thoughts were as well as more details inside on their newest Saint gruppo.
To know where you’re going, you have to know where you’ve been. It helps to have a knowledgeable background on what was before it and to say the Saint gruppo has come a long way would be an understatement. Almost every component in the new m810 Saint groppo has a clear vision of improvement in functionality, weight, and strength over the older m800 Saint gruppo.
The test bed for our 2009 Saint gruppo was the Cove STD (Skinnies, Trannies, Drops)
The shifters are reworked and it’s clear Shimano took some features from the previous Saint shifters (shorter paddles) and combined that with a few of the current XT/XTR features. The shifter can be adjusted on the clamp itself in a similar fashion to Sram shifters to deliver a wide variety of shifter positions. The one ailment of using smaller paddles makes removing the gear cable bolt a bit harder as the space to fit a screwdriver in between can be a little tight. As you can see below, the shifter tucks quite nicely underneath the Saint brake lever.
The Saint shifters can be adjusted further inboard or outboard via two 3mm allens
The shifter tucks nicely underneath the lever
The shifting also features a 2-way system so you can down shift in the normal Shimano fashion with your index finger, or push the lever with your thumb. Whether you like the classic Shimano trigger shifting methods or the push method of Sram, this new Saint shifter can do it all.
The lack of dual down shift (XTR can down shift twice with one stroke) is one downhillers won’t likely miss as unplanned double down shifts aren’t even a thought as you’re concentrating on maneuvering down the hill. When paired with the new Saint rear derailleur, shift pressure is increased in comparison to an XTR or even XT setup. While it doesn’t feel bad, it is something not typically prevalent when riding top end Shimano shifters and derailleurs.
| Part | Year | Real(g) | Pic. |
| 2009 Saint SL-M810 Front Shifter | 2008 | 114 | ![]() |
| 2009 Saint SL-M810 Rear Shifter | 2008 | 121 | ![]() |
| a |
The vision behind the Shadow technology implemented in XT and XTR have clearly influenced the new Saint lineup. The new Saint rear derailleur utilizes the Shadow technology in a medium cage(GS) and a small cage variant(SS). The new Saint derailleur will not allow the derailleur to clock froward past a certain point so the derailleur won’t be banging the chain stays on rough terrain. Additionally the Saint derailleur has a very tight profile to aid in giving more clearance between obstacles and vulnerable objects similar to the other Shimano Shadow derailleurs.
The 2009 Saint short cage rear derailleur gets the Shadow treatment
2009 Shadow technology reduces the derailleur profile to avoid damage
The rear derailleur also comes with a mode conversion that allows the derailleur to work with compact (23 – 28t low gear) cassettes or mountain cassettes (32 – 34t low gear). Since our setup was using an 11-28t SLX cassette (CS-HG80), the mode selector had to be removed. The pieces are small and pretty easy to misplace if you’re not careful. It includes two 2mm Allen bolts and a small spacer.
Mode adjust allows for mountain cassettes or compact cassettes to be used
The rear derailleur also has a nice integrated skid plate to help protect the derailleur as well, which is very nice to see on parts that often sees a beating on a gravity oriented bike.
The derailleur features a 10% stiffer spring than the XT/XTR Shadow derailleurs and is noticeably quite clicky in actuation in comparison to Shimano’s non-Shadow derailleurs and even their other Shadow derailleurs.
The derailleur has performed quite well so far on the Cove STD and didn’t prove to be too noisy. The rear derailleur can still make noise on its own as the derailleur is held forward by chain tension. Relieving and then regaining chain tension can essentially cause any Shadow derailleur to make noise on itself.
While we didn’t get a chance to fully test out the double setup they have designed (double specific front derailleur) it is a very relevant and timely component that is needed as more and more people are running double setups on their trail and all mountain bikes. The new front derailleur offers some very nice features that help to not only keep the chain on the chainrings but help properly take advantage of a two ring system in giving additional clearance and better shifting.
| 2009 Saint RD-M810 GS (Medium Cage) Rear Derailleur | 2009 | 246 | ![]() |
| 2009 Saint RD-M810 SS (Short Cage) Rear Derailleur | 2009 | 233 | ![]() |
| a |
The cranks were clearly reworked quite a bit and it shows. Lighter and stronger is something every company typically strives to do when refining a product but often can miss the mark. Shimano not only made these new cranks lighter, but stronger. If there’s one thing Shimano has typically done well it’s been their cranks and these Saint cranks deliver. They have used Duralumin (Hollowtech II) that was previously only used on XTR/Dura Ace cranks. Shimano claims these are twice as stiff as XT’s and it certainly feels stiff!
The 2009 Saint crankset gets slimmer and new graphics
The Saint specific bashguard worked well during the ride and took a few minor impacts well. The Honeycomb look is quite nice but can also become a collection plate for mud and grime. The bash was pretty light as a result of the cutouts. The crankset is available in a double 22/36 or a single ring setup with 34 – 42t offerings in even steps.
Honeycomb style on the backside
The Saint chain ring also saw some revisions and additional machining to make it lighter than the previous chain rings. More chain ring sizes are available (34-42t in even number increments). The cranks will be available in 165mm, 170mm, and 175mm.
There are a few additional noteworthy changes however that are worth mentioning that on the surface might not be as apparent. The spider as you might be able to see is reworked and fitting an after market bash ring on these cranks probably won’t happen (or be easy) until the chain guide companies start to make Saint specific bash rings as the spider has significantly wider chain ring mounting tabs.
An upgraded spider to help strengthen the chain ring tabs
Single ring chain guides that don’t mount a bash guard to the cranks, like the e.thirteen LG.1, won’t feel the effects of this as they don’t require a bash guard to be mounted to the spider or aid in the chain guides retention functionality. Additionally, you can also see how these Saint cranks will require no grinding of the granny ring tabs to fit a chain guide properly which is a nice bonus.
A solution (and one implemented on the Cove STD) was to use the Shimano Saint bash ring with the e.thirteen SRS backplate with some minor modifications. Using a Gamut style guide might prove to be quite difficult/impossible with these new Saint cranks until they make a Saint specific bash guard as using a Gamut bash guard will have the bash quite a bit further out from the chain.
Additionally Shimano has changed the stock Allen 5mm chain ring bolts to a Torx 30 which is an additional tool you’ll have to remember to bring along (or swap out the bolts to a 5mm).
Classic pinch bolts and an aluminum knob
The cranks remain a two-bolt pinch style which was great to see with an aluminum compression knob. A deeper bottom bracket cup is also included to have more threads contacting the frame for some additional security.
These new Saint cranks were a treat to ride once they were set up. The additional ankle clearance was quite nice especially on an 83mm BB shell. It gave not only better ankle clearance but they felt slightly narrower which should increase the potential for more power to be applied to the pedals. The cranks were solid and it’s clear they’ve lost no strength while reducing a little bit of weight as well.
| a |
This is an area where it seems every company has been stepping up and Shimano is no different. Starting at the levers, they’ve been reworked and are quite reminiscent of the new XT/XTR style mid/high pivot location and feature aluminum reach adjustment as well as an free stroke (adjustable pad contact point) screw.
The new Saint brake lever looks familiar on the surface
The Saint levers have a new lever as well that felt pretty decent. I’m not sure if I personally like the way the lever travels upon actuation but the feel of the Shimano Servowave technology is quite impressive. Looking at the lever more, you can see that there are a good bit of screws as well on the lever in general and the one piece clamp means you’ll have to remove your grips to install or remove them.
Shandro demonstrates the Saint lever actuation
Using the Saint servowave lever with the new 4 piston calipers and high power hose proved to be predictable and trustworthy from the instant I pulled the levers for the first time. The caliper is clearly reworked and if you’ve used the M755 4pot XT calipers, these have a reminiscent if not more powerful feel to them. The complete system garnished an impressive controlled braking experience, while still retaining tank like stopping performance. The banjo is positioned cleanly away from harms way as well.
The new Saint 4 Piston Caliper
The Saint calipers have an increased fluid capacity for the less caustic mineral oil as well as utilizing two different sized pistons to help control the power and pad wear. No top loading pads however.
The new Saint 4 Piston Caliper has two different sized pistons
Overall the brake system worked near flawlessly outside of some ambient squealing they seemed to develop after getting broken in. The calipers come with metallic pads and these are typically louder than organic pads so some noise was expected but we’ll be trying out some different rotors to see if we can alleviate some of the squealing. While some squealing can often be felt in the lever itself as a shuddering gobble, the Saint brakes did not feel this way which was good.
Brakes are one of the key parts on a gravity bike and the Saint brakes instill confidence. The brakes felt best under heavy braking (or last minute braking) but didn’t feel like they lost too much modulation in the slower sections that required a bit more finesse. It was easy to feel / predict the power of the brakes (especially at speed) and that is something a lot of brakes often lack.
Setting them up was easy with the Shimano mechanics and proper tools there but overall a solid bleed technique is a key part of making brakes perform to their potential. Additionally its worth mentioning that Shimano will be offering these new Saint brakes in a pre-bled package so no more having to build the system yourself. I’d like to have seen the free stroke screw be a more adjustable knob and have a better influence on the overall feel and setup. Essentially the free stroke was set and then ignored in setup as we adjusted the bleed to control the feel of the brakes for the most part.
The brakes could’ve been a bit lighter if a mono body system was used as well as possibly getting a bit more power out of the brakes. They come in at a very respectable weight given the amount of power they offered. While the open trails at Whistler didn’t offer the best locale to test long continued braking they never showed signs of fading or varying lever actuation.
| a |
The Saint wheels were laced up to some restickered DT Swiss rims. The front hub features angular contact bearings. The use of these bearings are seen in some frames (Knolly’s) to help alleviate side loads that cartridge bearings can’t absorb quite as well. The front hub also now accepts a “standard” centerlock rotor instead of the Saint oversized front centerlock. The hubs are available in jsut abouut every size you’d ever need ranging from 135mm (10mm or 12mm axle) spacing to 150mm.
A new Saint front hub uses a standard sized centerlock rotor and an external BB tool to remove the lockring
The rear hub features a micro ratchet freehub and now and has 36pt engagement which was nice to see carried over from XT/XTR. Previous Shimano hubs often had only 18 engagement points and as such felt lacking in comparison to higher end hubs. The improvements to their hubs in sealing and engagement help to bring the Saint hubs into contention with the nicer after market hubs. While still a little bit heavy in comparison to some of the lighter hubs out there, these new Saint hubs are much lighter than previous Shimano Saint hubs and are better in just about every way.
new Saint rear hub
| a |
Pricing (MSRP)
Brakes
Derailleurs
Shifters
Cranks
Hubs
The Complete System
Overall I was pretty impressed with the changes and improvements Shimano has made to the new Saint lineup. The brakes from a performance standpoint are possibly the best they’ve done for a downhill brakeset once you get used to the lever pull. The shifting was crisp but had a few minor areas where improvement could be made to quiet the drivetrain a little bit more. The cranks felt solid and were predictable but some consideration needs to be taken before deciding if these cranks are right for you and your application. As a gruppo they’ve done quite well. The perhaps final piece of the puzzle will be to develop a tubeless or DH rim to mount their Saint hubs to complete their package.
Shimano has done a nice job in my opinion in the changes and features they’ve made to the Saint lineup and while some issues are there, there aren’t any major make or break issues with the new gruppo. I suspect many of you will be pleased once you get to try it out for yourself.
Expect to see a lot of Saint equipped bikes next year not only on the OEM level, but on Trail bikes, and FR/DH bikes alike. It’s truly a well thought out gruppo that has taken into consideration many issues that the bashers, crashers, and racers desire in a gruppo.
Special thanks to Shimano for their warm hospitality and Gabe at Cove Bikes for supplying the STD frame to test out the new Saint products.
