The Transition BottleRocket is one of Transition’s most recognizable frames and for a good reason. The BottleRocket offers 5.5″ of travel and was designed for trails that have flow, jumps, and gaps. After riding some of Transition’s local trails it was quickly apparent where their inspirations came from for this bike, their trails. Their local trails in Washington and some the ones further north of them (Whistler) really define what the BottleRocket was designed to do. We opted to try out the BottleRocket again to revisit the bike in general, try it out with an air rear shock that a few of the guys at Transition recommended, and see how it stacked up against some other park bikes. While the bike on the surface looks the same as the ones from years past, the BottleRocket has had some subtle but smart changes to it that have this bike screaming the phrase “oldie but a goodie”. Transition is big on bringing a good bike at a great price to the consumer and this bike is no different.
Available in 3 sizes (small, medium, or large), the basic geometry behind the BottleRocket was designed with a low bottom bracket, short chain stays and ample stand over to give it quick mobility in every situation. The BottleRocket is a low single pivot at heart. The upper linkage is what Transition uses to control the shock rate, provide stiffness to help give a solid feeling bike, and help keep the shock safe and working properly day in and out.
One change is the shock mount is machined out a bit compared to the earlier BottleRocket.
The upper shock rocker is a one piece CNC’ed unit that is hollowed out a good bit compared to the early BottleRocket.
Older BottleRocket Linkage
The dropouts see some slimming down as well as getting some revisements to the rear end to make serviceability and reliability a little bit better. The older BottleRocket pivot used to screw directly into the frame. The BotttleRocket now has similar pivots as the Blindside that help with the overall pivot maintenance and reliability.
Old BottleRocket dropout area
A 135mm x 10mm or 135mm QR wheel fits easily in dropouts. We set our Industry Nine wheel for a 135 x 10mm thru-axle but easily could have set it up to accept a quick release.
The newer BottleRocket features a better welded ISCG-03 tab. The previous BottleRocket wasn’t welded around the bottom bracket shell as completely as this one is.
Additional CNC work was also done to the rear triangle.
A slimmer BottleRocket with a familiar feel to it is what we’ve felt so far. The BottleRocket we’ve previously tested had a heavier build spec but still managed to feel balanced and was a treat to ride. The RP23 with the small volume air sleeve in the rear added a bit more playfulness to the BottleRocket and gave it more pop off the lips of jumps but sacrificed some of the sensitivity of a coil. The BottleRocket loves to be in the air and was fun every time it took flight as all the BottleRocket was easy to manuver and command at will.
Up front we bolted a 1.5″ FOX Float 36 RC2 to the BottleRocket. The FOX 36 is one of Transition’s favorite forks on this bike and it’s for a good reasons. Stiff, plush, adjustable, and one of the best 160mm forks available. The axle system is not only tool free and easy to use, but it has been set and forget.
Syncros Bulk bar and Sunline Big Logo S lock on grips were used as part of the basic cockpit. For headset duties, we pressed in an FSA Orbit Xtreme PRO headset and used a Straitline 50mm 1.5″ SSC stem to round out the cockpit.
The MRP G2 Mini bolted up easily to the BottleRocket along with a 36t e13 guidering. The NukeProof Neutron TI Pedals were bolted on to try out as well.
A 135 x 10mm thru-axle was used to bolt the rear wheel to the frame.
The Hope Tech M4 brakeset handled the stopping duties. We opted to use some standard 7″ rotors as the floating rotors Hope provided caused some rubbing on the front fork brake arm in this fork / hub / brake combination since the floating rotor inside arms are wide on their floating rotors.
| Transition | BottleRocket Large (Frame Only) |
2009
3601 |
| FOX | RP23 7.875 x 2.25 |
2009
252 |
| Transition | QR 35mm seat post collar |
2009
41 |
| Transition | Shock Bolts |
2009
31 |
Our BottleRocket complete weighed in at 32.09lbs. More weights are available in our weight section if you’re curious about other part weights we used.
The BottleRocket is available now and you can learn more about the BottleRocket by visiting the Transition website. Transition doesn’t follow the model year that a lot of manufacturers follow but they update bikes as they see room to improve. Transition is very approachable and are always excited to chat about their bikes (or any bike if you’d like as well we’ve found). A complete review on this BottleRocket is in the works as well as a comparison between the park bikes we’ve selected so stay tuned to learn more as we get more time on them. Check back later to see more park bikes we’ve selected to include!
