Quantcast Which bike should i get? - Sick Lines Forums
Thread Tools Display Modes
  #1
Old 10-27-2007, 05:09 PM
Frankie Beanzzz
Guest
Posts: n/a
Hi my name is Frankie and my first post is a question to everyone. Their are 3 bikes that i want but i can't figure out which one to get. They all have great parts on them and they're about the same price range. The first one is the 07Specialized P. series, 07 Cannondale Chase2 and the GT Ruckus DJ. I know that both the Specialized and the Cannondale come in a large but I'm not sure about the GT. One more thing I'm 6'2 and about 220 pounds. I would definitely appreciate everyone's input. Thanx for your time.
  #2
Old 10-29-2007, 01:16 PM
jvnixon's Avatar
jvnixon jvnixon is offline
Administrator
Hey Frankie,
What do you plan on doing with the bike?
The Ruckus only comes in one (universal) size.
HEAD TUBE ANGLE:69
SEAT ANGLE:73.5
HORIZ. TOP TUBE LENGTH:592mm
SEAT TUBE LENGTH:385mm
CHAINSTAY LENGTH:410mm
STANDOVER HEIGHT:666mm
HEAD TUBE LENGTH:110mm
BOTTOM BRACKET HEIGHT:308mm
WHEELBASE:1082mm
FORK LENGTH:480mm
RAKE:41mm
Chase 2 Large
Seat Tube Angle (degrees)74
Head Tube Angle (degrees)69.0
Horizontal Top Tube Length (in/cm)24.0/61.0
Seat Tube Overall Length (in/cm)14.6/37
Chainstay Length (in/cm)16.7/42.4
Fork Rake (in/cm)1.8/4.5
Bottom Bracket Height (in/cm)11.7/29.8
Wheelbase (in/cm) 43.4/110.2
Trail (in/cm)3.1/8.0
Standover Height (in/cm)29.3/74.4
Bottom Bracket Drop (in/cm) 1.4/3.5
Front-Center Distance (in/cm)26.8/68.0
Actual Top Tube Length (in/cm)22.4/57.0
P Geometry depends on the model.
  #3
Old 10-30-2007, 03:19 PM
Frankie Beanzzz
Guest
Posts: n/a
Since i use to freestyle back in the day i would probably use it more for street. But there are these new trails here in New York i wouldn't mind trying out. As for the Specialized i forgot to mention it was the P.2. Thanx for the reply jvnixon.
  #4
Old 10-31-2007, 09:14 PM
jvnixon's Avatar
Administrator
Nice. I'd suggest trying to see if you can find anyone or a shop that has these that you can try out for yourself.
These two are pretty similar in geometry and depending on how you like your bike setup, these all could be a winner.
  #5
Old 11-02-2007, 07:31 PM
Frankie Beanzzz
Guest
Posts: n/a
I think i'm most likely going to get the P.2. I'm digging the paint job more on the P.2 than the Chase 2. Thanx for you input jvnixon.
  #6
Old 11-04-2007, 07:09 PM
jvnixon's Avatar
Administrator
Nice. P.2's are good bikes and I think you'll be happy with it.
I had a P.1 and P.3 previously as well and they worked fine.
Post up a picture when you get it if you want.
  #7
Old 11-06-2007, 01:41 PM
Frankie Beanzzz
Guest
Posts: n/a
I will definitly post a pic as soon as I get it.
  #8
Old 11-06-2007, 05:05 PM
jvnixon's Avatar
Administrator
Here's my old P1 frame that i used to have
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Design by Vjacheslav Trushkin.
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
