Quantcast 12mm rear axle tolerances - Sick Lines Forums
Thread Tools Display Modes
  #1
Old 07-15-2007, 08:15 PM
cooper_xl
Guest
Posts: n/a
Hi,
I'm making a floating disc brake adaptor but I don't know what bearing I'll use...my problem is that I don't know if I can use a bearing with 12mm inner diameter because of the axle's tolerances..and I can't just measure the axle because the "client" lives far away..
  #2
Old 07-17-2007, 01:38 AM
jvnixon's Avatar
jvnixon jvnixon is offline
Administrator
sorry no help here really... Shouldn't that be a standard number?
Are you connecting the piece to the hub somehow? or are you having it floating to the side of the hub?
Depending on the bike you're using... brake therapy did a really sweet job with integrating the floater a bit more by integrating the floater into the dropout like so:
http://www.sicklines.com/2006/08/23/...loating-brake/
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Design by Vjacheslav Trushkin.
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
