The new DASH has a lot of similarities with the recently launched BURN, but we promise it is a very different bike. It has always been our “slay any trail” machine, being the closest idea to Mountain Bike perfection that we can imagine.
Devloped by CERRO and Caesar Rojo who is an engineer and accomplished ex-World Cup downhill racer.
UNNO DASH Frame Details
Carbon fibre monocoque with 140mm of rear travel. Virtual pivot suspension system. Integrated chain guide and seat tube clamp. Down tube protector. EnduroMAX Bearings. Internal cable routing. Boost thru axle
12×148. Post Mount brake system. Max tire width: 2.5”. Oceanworks recycled plastic parts and rubber protectors. Recommended sag: 35% (+/- 5%).
DEUX ENDURO BARS
Integrated bars and stem. No-bolts design. Internal fork tube clamp. 800mm width, 20mm rise, 40mm stem.
For this, we increased the rear travel by +10mm. The result? A trail assassin with the right kinematics, the right geometry, the right wheelsize and a punch of energy in both uphills and downhills. Ain’t this what is MTB about?
Weight: TBC
140mm rear travel
Fox Float Factory X2 air shock Double Row EnduroMAX bearings
Wheel size: 29”
Shock size: 230×57.5mm
Shock tune: Custom
Seatpost diameter: 31.6mm
Max seatpost insertion: 235/250/280mm Headset: IS52 – ACROS Aix540 Integrated chainguide
Down Tube protector
Rear axle: Boost 148, 12mm thru-axle Rear brake mount type: Post Mount Rear rotor: 180mm
Max rear tyre width: 2.6” Recommended fork travel: 150mm
And here’s more good news: the DASH is in stock and ready to be shipped in the next days! We will priorize the S2 sizes. The S1 and S3 will be ready to ship in 2-3 weeks.
Read more about the new Unno Dash at https://www.unno.com/dash/
