13
Marzocchi Bomber Air Shock
6/13/2022 : sicklines
MARZOCCHI BOMBER AIR
SLIGHTLY OFF FOR THE SLIGHTLY OFF
June 13th, 2022: Available in a huge range of sizes, the new Marzocchi Bomber Air is a DH-rated shock featuring a purpose-built asymmetric reservoir, allowing for better frame fitment and compression adjuster access. Unique and proven shock internals combine playful and confidence-inspiring ride characteristics with our proven bomber durability.
KEY FEATURES
  • Asymmetric reservoir position for improved compression lever ergonomics and versatile frame fitment
  • Air valve location offers improved frame clearance and pump access
  • Easy to adjust for all rider weights and riding styles
  • Innovative tunable sweep dial to adjust the stop to a narrower window
  • DH-rated shock pairs well with all Marzocchi forks, from DJ all the way through to 58
  • 2-position, non-indexed compression sweep adjust means you can set it and forget it
  • Includes travel reducing spacers
  • Unique air volume spacers, available in 0.1 C.I. increment TECH SPECS
  • 40 to 75 mm stroke
  • Trunnion and standard eyelet options
  • Adjustable compression and rebound
  • All adjusters are tool-free
  • Compatible with FOX bearing mounts on both ends (excluding trunnion)
  • 484 grams (205×65)
  • Sizes: Metric: 190×45, 210×50, 210×52.5, 210×55, 230×57.5, 230×60, 230×65, 250×75 Trunnion: 185×52.5, 185×55, 205×60, 205×62.5, 225×75
  • MSRP: $479 USD / $619 CAD / €639 EUR
https://www.marzocchi.com/products/bomber-air
Cam McCaul
Jaxson Riddle
Martha Gill
Reed Boggs
Sam Soriano
