Canyon Dream Bike Build – Spectral 29 // Luca Cometti
3/24/2022 : sicklines
Two-time Dual Slalom U.S. National Champion, Cometti, is a bicycle connoisseur with a garage filled with bikes—from hardtails to cross-country bikes to e-bikes to downhill bikes. “Ever since I was a kid, I’ve been obsessed with all things two wheels,” says Cometti.
With the intention of creating a “quiver killer,” Cometti turned to master mechanic and master customizer Jason Guthrie of Chainline Bikes.  Using the Canyon Spectral 29 as the foundation, Cometti and Guthrie set out to create a “dream build”—selecting each part with purpose to be truly worthy of their shared obsession to build the perfect bicycle.
, Canyon Dream Bike Build – Spectral 29 // Luca Cometti
Dream Build – Canyon Spectral 125 – Specs
FRAME: Canyon Spectral 29, Large, 150mm travel
Custom Paint: Base—White, Accent—”Ochre”, Pinstripe—Silver leaf by Chainline Bikes
Suspension linkage: Stripped and polished by Romero’s Polishing
Downtube protector: Custom faux wood vinyl wrap
FORK: Fox 36 Factory, Grip2, 160mm travel
Lower legs: Custom paint—”Espresso”
Crown: Custom paint—White
Fork pinch bolt: Better Bolts titanium
PSI: 110
Low-speed rebound: 10 clicks
High-speed rebound: 4 clicks
Low-speed compression: 14 clicks
High-speed compression: 5 clicks
Volume spacer(s): 3
HEADSET: Canyon with brown-anodized spacers
STEM: FSA Gradient 35, 50mm length w/Better Bolts titanium bolts; custom polished finish by Romero’s Polishing
STEM CAP/BOLT: Better Bolts cap w/Titanium bolt
HANDLEBAR: FSA Comet 35, 25mm rise, 780mm width
GRIPS: Ergon GE1 Evo Slim, Sand Storm
BRAKES: TRP DHR EVO w/Better Bolts titanium bolts
ROTORS: TRP 2.3 x 180mm w/Better Bolts titanium bolts
RIMS: FSA Straight-pull, 14-gauge
HUBS:FSA Afterburner, 24-hole
RIMS: FSA Afterburner, 24-hole; custom chrome graphics
INSERTS: Tannus Armour Tubeless (r), Tannus Armour (f)
TIRES: Kenda Hellkat EMC 29”x2.4” (f), Kenda Hellkat Prototype 29” x 2.4” (r)
REAR SHOCK: Fox Float X2 w/Real World Cycling needle bearing and DU bushings
PSI: 180
Low-speed rebound: 13
Low-speed compression: 18
High-speed compression: 8
Volume spacer: 1
SEAT POST: FSA Flowtron, 150mm travel
SEATPOST CLAMP: Canyon w/Better Bolts titanium bolt; custom polished finish by Romero’s Polishing
SADDLE: Ergon SM Enduro Comp; custom Thrill Seekers cover
BOTTOM BRACKET: FSA BB392
CRANK:FSA Gradient, 170mm; custom polished finish by Romero’s Polishing
CRANK SPIDER: OCHAIN with 6-degree engagement
CHAINRING: SRAM 34T
PEDALS: Crankbrothers Mallet DH 11
CHAIN: SRAM GX
CHAINGUIDE: Canyon Integrated
CASSETTE: SRAM XX1, Gold, 9-50T
SHIFTER: SRAM GX AXS
DERAILLEUR: SRAM GX AXS
