Presenting The New Roval Traverse Alloy
Hungry for the Trail, Easy on the Wallet
May 24th, 2021, Morgan Hill, CA – Shred without overthinking it. The brand-new, Tubeless-ready Traverse Alloy brings mountain-taming performance slightly closer to earth with a carefully selected build designed to let riders take full advantage of the low rim and spoke mass.
This new wheel offering employs the performance specifications from the Traverse carbon range and utilizes a rim extruded from high-strength E5 aluminum alloy. Only 70g heavier than the Traverse Carbon wheelset (29) riders can rally this wheelset day-in and day-out.
Traverse Alloy is the training wheel of choice for the Specialized Enduro Team for its durability, flex, and trail feel.
RATCHET LN: The new Traverse wheels imply DT Swiss’s new Ratchet LN technology, bringing improved engagement and durability to the wheel. This is a tremendous upgrade, and riders can further upgrade through DT Swiss’s high-end Ratchet’s, all the way to 54 tooth engagement. The Ratchet LN system also allows older Roval wheels to be upgraded for a fraction of the cost of a new wheel, keeping more rims, and hubs rolling longer.
With an internal rim width of 30mm, ideal for wider tires; this wheelset can handle both days at the bike park and epic climbs. Dependable DT 370 Ratchet LN internals, sealed bearings, spokes of equal length on each side for both front and rear wheels are just a few of the provisions that make these wheels durable, serviceable, and hassle-free.
Product Specifications:
30mm Internal Rim Width
Alloy Clincher
Tubeless Ready
Roval CNC machined “Step Flange” DT Swiss 370 6-bolt Hub – 18t Ratchet LN System
Thru Axle: 110x15mm & 148x12mm
29 Front Right/Left: 283mm/283mm
29 Rear Drive-Side/Non-Drive: 283mm/283mm
27.5 Front Right/Left: 266mm/266mm
27.5 Rear Drive-Side/Non-Drive: 266mm/266mm
Set Weight: 29 -1870g; 27.5 – 1830g
MSRP: $650.00 – Wheelset
Product Details and Purchase
