Cane Creek eeWings Aluminum and Carbon Seatpost Options
3/2/2021 : sicklines
, Cane Creek eeWings Aluminum and Carbon Seatpost Options
Cane Creek announces new eeSilk and eeSilk Carbon seatposts.
Asheville, NC- March 2, 2021
We are proud to announce the next generation of eeSilk post from Cane Creek Cycling Components. With the same fatigue-reducing 20mm of travel as its predecessor, the new eeSilk has been refined with accessibility in mind. This has enabled us to reduce the retail price of the post to $199 without sacrificing quality or performance. We have also added a new carbon post option – the eeSilk Carbon – to further ensure that the eeSilk is among the lightest performance suspension seatposts available to riders. The eeSilk carbon is available for riders at a retail price of $299 – only $10 more than the original eeSilk post.
Like their predecessor, the new eeSilk and eeSilk Carbon are performance suspension seatposts designed to add comfort and reduce fatigue on road and mixed-surface rides without adding unnecessary weight to the bike. These posts make great enhancements to endurance road bikes by reducing the chatter transmitted from the surface to the rider and can be tuned to rider weight through a simple elastomer change.
The new eeSilk features stainless steel hardware and is available in 27.2mm and 31.6mm seatpost diameters with an increased seatpost length of 375mm to accommodate bikes with a lower top tube. The eeSilk Carbon comes with the same titanium hardware and custom titanium thumbwheel as the original eeSilk and is available in both 27.2mm and 31.6mm diameters with a 350mm post length.
The axles on both posts have been upgraded from hollow aluminum to solid 300-series stainless steel and the bushings have been moved from the seatpost arms to inside the seatpost head and cradle. These changes make for a longer lasting and quieter pivot design. The arms have also been redesigned to create a lower profile and provide an even longer lasting suspension mechanism.
The new eeSilk and eeSilk Carbon are available for order now through Cane Creek retailers and distributors or factory-direct in North America through www.canecreek.com
Specifications:
MSRP
eeSilk – $199
eeSilk Carbon – $299
Weight
eeSilk – 27.2mm – 345g; 31.6mm- 350g
eeSilk Carbon – 27.2mm – 295g; 31.6mm – 305g
Dimensions
eeSilk – 27.2mm and 31.6mm post diameters; 375mm length
eeSilk Carbon – 27.2mm and 31.6mm post diameters; 350mm length
Materials/construction
eeSilk – Aluminum Shaft, 300 series stainless steel axles, stainless steel hardware
eeSilk Carbon – Carbon shaft, 300 series stainless steel axles, titanium hardware
Travel
20mm (both models)
Offset
8mm (both models)
Maximum Rider Weight
250lbs / 113kg (both models)
