Canyon has a new Strive for 2021 featuring their Shapeshifter technology and 170mm of front wheel travel. Check out the details on the Canyon Strive CFR 2021 inside.
We reviewed the previous Canyon Strive CF 8.0 so check that out if you haven’t seen it yet as well. Today Canyon announces new Strive models including Strive CFR, Strive CF8, and Strive CF7.
Canyon’s out-and-out enduro machine, the Strive, has received more than just a fresh coat of paint for 2021. Based around a tough, race-proven, full-carbon frame, the Strive is fast everywhere—from high-speed rock gardens to awkward slow- speed corners and energy sapping traverses. Enduro racing demands versatility from both the rider and the bike. While 2020 has been an unpredictable year on all counts, with Jack Moir joining our Canyon CLLCTV Enduro Team, the Strive remains one of the fastest enduro bikes on the planet.
Keeping the Strive on race-pace for 2021 is its innovative Shapeshifter technology. Produced in close collaboration with our partners at Fox Suspension, the Shapeshifter offers on-the-fly adjustment for both geometry and rear- suspension travel.
At the push of a lever, you can switch between descend mode (with low, slack geometry and supple suspension performance) to climb mode (sharpening the handling and raising the BB) while simultaneously reducing the available travel at the rear and firming up the suspension.
All models in the range now feature 170mm travel forks, a tweak which was previously reserved for CFR bikes. This raises the front end and slackens the head tube angle for increased capability on steep, technical descents. Also new for 2021 is the move to GRIP2 dampers on the Fox fork equipped CF 8 and CFR models, letting you eke out even more traction from your setup.
The capability has been boosted in other areas too. The CFR, for example, is now equipped with DT Swiss’s gravity focussed EXC 1200 carbon wheels and a FOX 36 Factory fork. The CFR model also see the inclusion of One Up’s V2 dropper post, while across the entire Strive range the droppers get more travel (depending on size). The Strive still rolls on Maxxis tyres, only now the rear Minion DHR II tyre moves to an even more durable EXO+ casing and the front tyre has been switched to one of the new kings of all-round performance, Maxxis’ Assegai.
Finally, there’s the colours. X-Ray green is no longer reserved for the likes of Tahnee and Kaos Seagrave- and features as an option on the CF 7 and CF 8 models, while the CFR sees a move to the super sharp black/ white colourway.
*Eurozone pricing **CUS availability differs
Three Strive models are on offer to American riders, starting at $3,599 for the CF 7, with a race-ready build and a full carbon frame. The CF 8 rolls in strong at $4,599 with a full XT drivetrain, FOX 36/DPX2 suspension combo, and DT Swiss E1700 wheelset.
The top-end CFR model at $6,999 is something special, however. A bespoke frame layup and ultra-premium material mix saves 300g over the standard Strive CF, and the build is dripping with top-drawer components including the aforementioned DT Swiss carbon wheels and FOX 36 Factory fork, pluse Code RSC brakes and a SRAM X01 Eagle groupset.
See more details at https://www.canyon.com/en-us/mountain-bikes/enduro-bikes/strive/
