WANDRD Nylon Camera Straps – Wrist, Neck, Sling
11/10/2020 : sicklines
WANDRD Nylon Camera Straps Wrist Neck Sling, WANDRD Nylon Camera Straps – Wrist, Neck, Sling
WANDRD has three new 100% recycled nylon camera straps that were released today. They make for great stocking stuffers for the holiday season for the camera lover in your life with their simple quick connect system.
“We aren’t fans of scratching up beautiful camera bodies or sounding like Santa with bells jingling’ everywhere we go,” says Spencer Cope, WANDRD co-founder and product designer. “So, we designed a sleek, quick connect system that doesn’t leave anything behind, and has no metal hardware directly attached to your camera. And as if that isn’t already awesome enough, we threw in some more rad features — custom metal hardware, a hidden ‘flathead key’ to connect and disconnect your camera plate, quick adjustments at both ends of the strap, and non-slip silicon printing to make sure the strap stays put.”
The Neck Strap: $24
The WANDRD Neck Strap is a simple yet dialed solution for smaller point & shoot style cameras. Our high-quality custom hardware was designed to easily attach to any camera and is an anchor-less system, meaning you’ll never have to leave any hardware behind. You can also use the Neck Strap to carry your keys, wallet, or soccer-mom whistle.
FEATURES
  • Universal Camera Attachment System
  • Custom WANDRD Aluminum Clips
  • Hypalon attachment loops rated to 75lbs
  • Minimalistic carry for small film cameras and point and shoot
The Wrist Strap: $29
The WANDRD Wrist Strap is the perfect low-profile safety tether for any camera, protecting your precious (and oh-so expensive) gear from accidental drops while on the go. And speaking of drops, if you do accidentally drop your camera our self-tightening hardware system locks the strap to your wrist. The high-quality custom hardware was designed to easily attach to any camera and is an anchor-less system, meaning you’ll never have to leave any hardware behind. Built with our recycled “soft touch” nylon, the Wrist Strap is as comfortable as it is durable.
FEATURES
  • Hypalon attachment lopps rated to 75lbs
  • Easily adjustable system that fits any wrist size
  • Auto locking system that secures the camera to wrist if dropped
  • Carry anything from a point and shoot to a DSLR
The Sling Strap: $54
The WANDRD Sling Strap is an absolute workhorse of a camera strap that can be carried three different ways – sling, neck, or shoulder carry. With two lightning-quick adjusters, you can rapidly switch between carry modes so your camera is comfortably in tow — whether you’re simply strolling through town or dangling from Dawn Wall in Yosemite. The high-quality custom hardware was designed to easily attach to any camera and is an anchor-less system, meaning you’ll never have to leave any hardware behind. The recycled “soft touch” nylon, built-in flathead tool, and non-slip silicone print all ensure the strap is nothing but a pleasure to use.
  • Hypalon attachment loops Rated to 100lbs
  • Neck Carry, Shoulder Carry, Sling Carry
  • Custom silicone no slip print
  • Carry anything from a point and shoot to a Pro DSLR Built in Flat-Head tool
  • Custom Dual Quick Adjustment System
