2020/2021 Formula Mod Shock
9/27/2020 : sicklines
, 2020/2021 Formula Mod Shock
Formula has a new shock they’ve developed called the Mod. It features their replaceable Compression Tuning System (CTS) that is similarly featured on their forks.
The Mod has an unconventional design that, thanks to the CTS (Compression Tuning System) technology, will allow every rider to fine-tune the rear suspension simply and effectively. The High Flow design of the damping allows for uncompromising reliability. Thanks to its large-volume bladder, the Mod manages to have very low friction and excellent small bump compliance.
Learn more about this new shock on the Forumla Mod webpage
SIZES
Standard210x55, 230x65Trunnion185x55, 205×65
ADJUSTMENTS
Compression17 Click Adjustment
Rebound13 Click Adjustment
CTSGold, Orange and Green valves included
Lockout
COLORS
Shock body Glossy black
Coil springs Ultraviolet, titanium
COIL SPRING
Sizes (lbs/in)300, 350, 400, 450, 500, 550, 600
Material: Ultralight steel
HARDWARE
Sizes (mm)20×8, 22×8, 25×8, 30×8, 35×8, 40×8, 22×10, 25×10, 30×10
WEIGHT
210×55 with 300 coil spring 670g
