KOBLENZ, AUG 2020 The Canyon Sender CFR debuts as two complete models: the Fox-Shimano equipped Sender CFR FMD (€4,699/$4,699)* and the RockShox-Sram equipped Sender CFR (€5,799/$5,799). Both models will be immediately available in markets outside of the United States. Riders in America will have access to both models soon thereafter.
The Sender CFR’s geometry gives riders what it takes to win on modern DH courses. The longer wheelbase increases stability at high speeds.
Adjustable reach and chain-stay length give the Sender CFR unrivaled versatility, enabling riders to tune the bike to their ride style or to the demands of the day’s track.
The MY21 Sender CFR rolls on big wheels, increasing rider speed through rocks and roots. Large and XL versions get the full 29er treatment. Small and Medium models go “mullet” (29” up front, 27.5” out back) for the win.
The mullet option provides shorter riders with many of the same roll-over benefits, while providing them with crucial clearance on steeper courses.
We shaved more than 600 grams from the carbon Sender chassis yet maintained the durability needed to withstand seasons of abuse. Carbon chain and seat-stays, a new shock-mount location, and precise shaping of every bit of the bike helped us cut weight without sacrificing strength or durability.
Excessive pedal kickback tires riders and reduces your suspension’s effectiveness. After years of research and testing, Canyon optimized the Sender CFR’s kinematics to reduce pedal kickback to levels that are virtually undetectable on the trail. End result? The new Sender CFR is remarkably fast and smooth through the nastiest sections of trail!
We designed more progressivity into the Sender CFR’s kinematics, allowing you to ride hard and fast (and to sometimes come up short) without blowing through your rear suspension travel.
2021 Canyon CFR Models
2021 Canyon CFR FMD Models
How does the anti rise, leverage ratio, anti squat compare? Check out the charts below.
Check out the picture below to see the changes they’ve implemented in the new version compared to the earlier Sender model
Canyon CFR Sender and FMD Model Pricing (USA / EU / NZ / etc)
