RockShox has updated the DebonAir on their 2021 forks and more. Read the details inside.
THE UPDATED DEBONAIR
The highly-tunable DebonAir air spring is ready for whatever the trail demands. Buttery smooth feel off the top, now optimized to maintain higher ride height and add more confidence on technical terrain.
FAQ – ROCKSHOX DEBONAIR UPDATES
How have you made the fork ride higher?
The new DebonAir air spring moves the piston into the dimple, which means the ride height from top-out to sag is higher and riders benefit from more initial support while achieving full travel when needed.
What changes have been made to the fork chassis?
The CSU and lowers remain the same, as well as the damper. The changes are to the air spring, where there’s an updated aluminum seal head with internal bushing, and also a new longer foot-nut at the bottom of the air spring shaft.
Is the new air spring backwards compatible?
Yes, the new air spring is backwards compatible across previous generation Lyrik and Yari as well as Pike and Revelation forks. There are two distinct air springs for the different fork chassis designs. You can also upgrade an MY20 air spring using the footnut and seal head spare parts rather than purchasing a complete air spring for your fork.
Why is the fork now easier to set up and equalize?
We’ve moved the piston up so that it sits in the dimple all the time while maintaining the same positive and negative volume. We’re still able
to equalize the tube between the two chambers, which now happens automatically – in turn they’re much easier to set up for a rider.
What do the changes to the foot-nut and seal head do?
We’ve changed those two parts together, making them longer to move the air piston up 10 millimeters to sit in the dimple.
Have the air volumes changed?
The volumes have changed, and there is a little less positive volume now.
The new seal head looks hollow at the bottom – why is that?
We learned with BoXXer that creating air volume under the seal head meant increasing the volume in the lower legs at bottom out. This means less lower leg air volume ramp up at the last part of the stroke. This increase in lower leg volume combined with the decreased positive volume means that the force to bottom out is virtually unchanged
Has setting sag changed at all?
We found that some riders were correcting the initial part of the stroke by putting more air pressure in the fork, which in turn held the fork up a little. The problem here is the increased pressure means getting full travel is harder. By repositioning the piston into the dimple, we have increased ride height and eliminated the need to over pressure for initial stroke support. Therefore, the fork rides higher and a rider gets full travel when needed.
Has the air pressure chart for Lyrik changed?
Lyrik will keep the same air pressure chart. With the same pressure it will ride higher in the travel. This keeps the fork from diving in steep terrain, and also allows full use of travel. The extra support keeps the fork taller, bar higher, and increases confidence to smash through the roughest terrain.
Has the air pressure chart for Pike changed?
We have reduced the pressure on the air pressure charts for Pike and Revelation as their sportier set up meant the changes in the air spring made a more drastic impact to the ride height and support. By reducing the pressure by approximately 5 PSI we have matched the spring characteristics in the latter part of the stroke while improving ride height and support in the initial part of the stroke.
Does the new air spring change the spring curve at all?
We have been able to improve the initial part of the stroke providing more support and ride height, but the overall spring curve is very similar. There is also a small change to the dimple bypass effect on the spring curve – with previous generation air springs, there would have been a small but noticeable downwards spike in the spring curve where the air changes across the dimple. The new air spring has eliminated that little downwards spike as the piston head sits in the dimple to begin with.
Look at the comparison shots below for the difference between the old DebonAir vs the new one
CONFIDENCE HIGH
OPTIMIZED FOR A BETTER TRAIL EXPERIENCE.
Every millimeter matters, especially when it comes to charging down steep, technical terrain. Based on rider feedback, the updated DebonAir air spring has even more initial support and adds a whole lot more confidence to the ride. It only took a few tweaks to get it just right. By moving the air piston position relative to the dimple, we increased the ride height from top out to sag. This means more initial support and the use of every millimeter of travel available to stay on top of the terrain.
Pike
A TRUE TRAIL MACHINE
Designed for today’s top trail-dominating dream bikes and ready for any conquest you’ve got planned. Ticking all the boxes, each and every detail made to reduce friction, minimize rider fatigue, and provide unmatched control over any trail.
PIKE ULTIMATE
FS-PIKE-ULT-B4
A true trail machine we couldn’t wait to have on our bikes and get to you. Featuring an updated DebonAir air spring paired with our Charger 2.1 damper for unmatched trail control for every sweeping corner or loamy drop in. Ultra-low friction SKF wiper seals and Maxima Plush damping fluid all work overtime to reduce friction, silence noise, and provide lasting fork performance.
FEATURES
Updated highly-tunable DebonAir air spring offers a buttery smooth feel off the top and maintains a higher ride height for increased confidence in steep terrain
Designed to reduce hand fatigue and fight unwanted friction, the Charger 2.1 damper increases confidence and control over every trail
Charger 2.1 RC2 damper option featuring independent high and low speed compression adjust
Ultra-low friction SKF wiper seals provide long lasting fork performance and improve overall suspension feel
Maxima Plush damping fluid reduces friction and silences damper noise
Gloss Silver Signature color option
SPECIFICATIONS
Wheel size: 27.5″, 29″
Travel: 130mm, 140mm, 150mm
Damper: Charger 2.1 RC2
Offset: 37mm (27.5″), 46mm (27.5”), 42mm (29″), 51mm (29″)
Upper tube: 35mm tapered wall aluminum
MSRP: $899 | €979* | £869* | *INCLUDES VAT | EMBARGO: APR 9, 2020 | RETAIL: APR 2020
PIKE SELECT
FS-PIKE-SEL-B4
Pike Select combines an updated DebonAir air spring with the Charger RC damper, perfect for any trail junket you have planned. As a bonus, we included race-proven Maxima Plush fluid to help reduce friction, silence noise, and keep things running smooth ride after ride.
FEATURES
Charger RC damper featuring low speed compression adjust
SPECIFICATIONS
Damper: Charger RC
MSRP: $699 | €759* | £679* | *INCLUDES VAT | EMBARGO: APR 9, 2020 | RETAIL: APR 2020
Lyrik
ALL ABOUT THE EARNED BLISS
Gotta get up to get down. We’re all about the earned bliss. Steeper, longer, rockier and now with more transfers in between— enduro riders all over the world are upping their game. If it’s a big mountain excursion or the coveted weekend podium you’re after, Lyrik is ready to help you conquer it all. Bring snacks and enduro on.
LYRIK ULTIMATE
FS-LYRK-ULT-C3
Designed not only for the race down, but the ride up. Holding onto every critical line, Lyrik Ultimate features an updated DebonAir™ air spring paired with our Charger™ 2.1 damper for unmatched trail control and precision. Ultra-low friction SKF wiper seals and Maxima Plush damping fluid all work overtime to reduce friction, silence noise, and provide unmatched fork performance sun up to sun down.
FEATURES
Charger 2.1 RC2 damper featuring independent high and low speed compression adjust
Ultimate foil graphics package
“BoXXer” Red Signature color options
SPECIFICATIONS
Travel: 150mm, 160mm, 170mm, 180mm
MSRP: $949 | €1,039* | £929* | *INCLUDES VAT | EMBARGO: APR 9, 2020 | RETAIL: APR 2020
LYRIK SELECT
FS-LYRK-SEL-C3
For all the ups, downs and to get you to everything in between. Lyrik Select combines an updated DebonAir air spring with the trusted Charger RC damper for unmatched trail control and precision. Maxima Plush fluid reduces friction, silences noise, and provides all-around lasting performance.
FEATURES
SPECIFICATIONS
Damper: Charger RC
Offset: 37mm (27.5″), 46mm (27.5″), 42mm (29″), 51mm (29″)
MSRP: $749 | €819* | £729* | *INCLUDES VAT | EMBARGO: APR 9, 2020 | RETAIL: APR 2020
Yari
A GATEWAY TO BIG ADVENTURE
Yari shares the stiff, hard-hitting Lyrik chassis designed to inspire confidence for those hard-hitting enduro riders and E-MTB riders alike.
YARI RC
FS-YARI-RC-B3
Yari shares the stiff, hard-hitting Lyrik chassis and combines it with the updated DebonAir air spring and proven Motion Control™ damper. Designed to inspire confidence for those hard-hitting enduro and E-MTB riders alike.
FEATURES
New graphic package for a fresh, premium look
Motion Control damping featuring low speed compression adjustment
Chassis derived from Lyrik
SPECIFICATIONS
Wheel size: 27.5″, 29″, 29″+
Damper: Motion Control
Offset: 46mm (27.5”), 42mm (29″), 51mm (29″+)
MSRP: $499 | €539* | £479* | *INCLUDES VAT | EMBARGO: APR 9, 2020 | RETAIL: APR 2020
Revelation
REVELATION IS HAVING A REVELATION
With 35mm upper tubes and a chassis derived from Pike, Revelation is ready to tackle the ever-changing challenges the trail may take.
REVELATION RC
FS-RVL-RC-A3
Revelation is all grown up and ready to explore wherever the trail may turn. Value packed, the Revelation features the updated DebonAir air spring paired with the Motion Control damper and 35mm Fast Black upper tubes.
FEATURES
Motion Control damping featuring low speed compression adjustment to firm
Chassis derived from Pike
SPECIFICATIONS
Travel: 120mm, 130mm, 140mm, 150mm
Upper tube type: 35mm tapered wall aluminum
