Deity’s line of bar and stems have been popular upgrade items for high-end builds for years. Despite their popularity, Deity didn’t have a 35 mm diameter bar/stem combo until last year. Deity took their time moving to 35 mm and rightfully so. Many 35 mm bars on the market are simply too stiff for anyone who’s not a 250 lb gorilla. Instead of resulting in a “precision” feel, they can just feel harsh. We threw the new 35 mm Speedway bar and Copperhead stem setup on our project Nicolai G-1 build along with their Knuckleduster grips and spent a few months riding them. Read on to learn more.
Speedway bars are a DH/enduro focused carbon bar available exclusively in 35 mm clamp diameter. They feature a 9º bend, 5º upsweep, and are available only in 30 mm rise. Deity included a few of small details in the Speedways to set them apart from the crowd, like textured grip ends to help keep your grips from spinning. The Speedways measure 810 mm wide with plenty of room to trim them down. I trimmed our tester bars to my preferred 780 mm width and there’s plenty over clearance to trim them further should you prefer your bars on the narrow side. Riding the Speedways, the 30 mm rise was just perfect for getting the front end a little higher on our project Nicolai G-1. On longer reach bikes (and the G-1 is one of the longest out there), I prefer a higher bar to more easily un-weight the front end and maintain a more upright position when charging steeps. Critically, the Speedway lends a solid and direct feel without being overly harsh. On late summer bike park laps when the dirt is full pot holes and braking bumps and hard as concrete these bars absorbed vibration as well or better than any other bar I’ve tested.
The Copper Head stem is Deity’s new 35 mm clamp stem. It’s available in 35 mm and 50 mm lengths, both with 0 rise. stack height is fairly low at 33 mm which when combined with the wide, 55 mm clamping surface, gives this stem an aggressive look. The Claimed weight is 135g which is right in line with other full-strength 35 mm stems. I really dig the machining detail on this stem and, from a practical standpoint, that all bolts heads take a 5 mm allen key.
Handlebar mounted pillows, that’s what we have right here folks. These are some of the cushiest grips I’ve tried. The wide raised ribs set these grips apart from the crowd in how much they take the sting out of pot holes and vibrations. There’s no outer lock ring to bother your hands and they don’t suffer from any throttling thanks to a tapered tube which requires the grips to be tapped into place. The half-waffle pattern on the inside makes for great My only minor quarrel is that the rubber is not particularly sticky making gloveless riding on hot days a definite no-go in the humid Pacific Northwest. The upside to that is the rubber is extremely durable and after a full season of use, my tester set have plenty of life in them.
Speedway bars
– MSRP $169.00
– 30 mm rise
– 810 mm width
– 35 mm diameter
– 245g weight (claimed)
– 9 color-ways available
– lifetime crash replacement policy
Copper Head Stem
– MSRP $98.99
– 35 and 55 mm lengths available
– 33 mm stack height
– 135g weight (claimed)
– 8 color-ways available
Knuckleduster grips
– MSRP $21.99
– 132 mm length, 32 mm diameter
– Single clamp design
– 101g weight (claimed)
