Transition Bikes has updated the Scout for 2020. They’re calling it their modern day take on the Bottlerocket and you can read all about the new bike from Transition inside.
Photos: Transition Bikes
Hop on the Scout and you’re immediately transformed into a projectile.
Our modern day take on the Bottlerocket, the Scout will awaken your inner child. Manual here, scrub that, skid there, pedal up this. Freedom to boost everything in sight, overshoot every landing without a care, mixed with nose bonking, corner slapping and hooting your way down the trail. Sporty, but just as eager to tackle bigger terrain.
The Scout’s trail charisma is infectious and will cause you to look at your regular trails through a new perspective. Pedal up and repeat.
Carbon Scout – Now with LIFETIME WARRANTY.
X01 Scout Carbon Complete in Midnight Blue ($6,599)
GX Scout Carbon Complete ($5,499)
NX Scout Carbon Complete in Olive Green ($4,499)
Available NOW at your local Transition dealer and our webstore!
TECHNICAL UPDATES AND STUFF
The Scout features a full carbon frame made from premium Japanese Toray fiber with a tailored blend of 24T and 30T materials to create the right balance of frame stiffness, strength, and impact toughness. Our unique latex coated EPS molding process allows for sharper frame lines and tighter edge radius control with maximum strength to weight ratio and less wasted material.
The 25% overall progression with a linear rate of change works well with air or coil shocks. The stock 57.5mm shock stroke provides 140mm of rear wheel travel, with the ability to use a 62.5mm stroke shock to get 150mm travel and large usable sag range let you custom tailor your ride.
GiddyUpStokeOptions Scout
Dropper posts keep getting longer so we combine short seat tube lengths with mega seatpost insertion to help get your saddle completely out of the way. All complete bikes come with longer travel dropper posts; XS 120mm, SM 150mm, MD 180mm, LG/XL 210mm.
TRANSITION LIFETIME & STANDARD WARRANTY COVERAGE
At Transition Bikes we take pride in the quality of our products. Our frames are manufactured for specific uses to withstand the rigors and abuse modern mountain bike trails can dish out. That being said, all frames can break given just the right amount of time, wear, neglect, or misfortune. Transition Bikes is fully committed to keeping you riding and we will do anything we can to keep a Transition Bike underneath you.
All Transition Bike models released 2020 and on are covered for the lifetime of the frame against material defect and manufacturing quality for the original owner. Models released before 2020 fall under the previous warranty. Model year 2018-2019 for 3 years from purchase date. Model year 2017 and older for 2 years from purchased date. Transition Bikes will repair or replace any original purchasers individual frame parts or complete frame at our discretion.
You must register your frame on our site with your serial number and provide proof of purchase to qualify for a warranty. In the event of an issue with your frame Transition Bikes will determine whether it qualifies a ‘Warranty Issue’ or is covered under our ‘Crash Replacement Policy’ (see below for details).
In the event that you have to send back all or part of your frame under warranty, you are responsible for the shipping costs to get it to us and we will pay the return shipping. Our warranty policy does not cover any labor costs, modifications from stock or normal wear-and- tear damage.
CRASH REPLACEMENT
In addition to our warranty, all Transition Bikes frames are covered for life under our “Crash Replacement Policy” to the original or second hand owner. If for any reason (and we do mean “any” reason) you should find yourself with a broken or damaged frame, you may send us the broken frame section and we will replace it at a cost well below retail, assuming we have the replacement part available. If we do not have the piece available we will attempt to work out a crash replacement price on a replacement frame set. You are responsible for all shipping costs to get the frame to and from Transition Bikes.
REMEMBER, WE’RE PULLING FOR YOU – WE’RE ALL IN THIS TOGETHER
Above is our official stance, since to some degree these things need to be spelled out. But our entire philosophy is based around being a rider-owned company, and we take that seriously. We’re well aware that not every circumstance can be accounted for and not every case falls neatly into one of the above categories. Our goal is to leave no rider who supports us without some form of support in return. Please contact us with any questions if you need help to keep your wheels rolling.
