2020 Troy Lee Designs D4 , D3, Stage, A1, A2
2/12/2020 : sicklines
Troy Lee Designs has released their 2020 D4 helmet lineup. Check out the details inside from TLD.
It’s the most iconic, most storied and most chosen Downhill, Freeride and BMX race helmets in bicycling history. First introduced in 1996, the legendary Daytona led the modern era of mountain biking and BMX with a magical blend of style and innovation. The Daytona and its successors, the D2 and D3, have been worn by more MTB and BMX heroes—and have collected more titles, medals and accolades and YouTube views than any other helmet in history.
And now, the all-new D4 Textreme® Carbon Fiber and D4 Composite helmets are ready to chase another era of championships. The perfect blend of Art, Science, Speed and Style, the new D4 will once again change everything. #LegendRedesigned
, 2020 Troy Lee Designs D4 , D3, Stage, A1, A2
The all new D4 Helmet has already racked up huge wins in competition as well with Brandon Semenuk winning the 2019 RedBull Rampage this fall, Alise Willoughby winning the first 2 rounds of 2020 UCI BMX Supercross and Nikita Ducarroz winning BMX freestyle simple session in Estonia!
Carbon D4 Models
D4 TeXtreme® Carbon Technical Specs (MSRP $575)
    TeXtreme® ‘Spread tow’ carbon fiber shell
    Lightest Carbon DH/BMX Race helmet we have ever built at 1000g (+/- 50gm and Size M)
    MIPS C2 brain protection system-protects against rotational impacts
    Front air intake system with high flow-through polymer center grille and power grid side mesh
    24 total vents: 11 front intake ports, 6 overhead intake vents that channel air on top of your head and an industry leading 7 rear exhaust ports
    Anti-Microbial/Quick Dry XT2®
    Quick release contoured 3D cheek pads create an anatomically optimized fit. Separately placed X-Static® & XT2® precision fit headliner with 7 anchor points gives you optimal fit
    EPP Collarbone impact system; a relief area that reduces the forces in the center lower section of the helmet where shoulder/collarbone impacts have been known to occur
    In-molded polycarbonate front brow and vent ports for increased impact strength
    Titanium D-Ring fasteners
    40mm of vertical visor adjustment with smart-shear breakaway visor screws
    EPP interior injected chin-bar
    Factory pilot helmet bag included
    3-year warranty
    3 Shell sizes and 3 EPS sizes, 6 total size ranges from XS-XXL (AS/NZ – 3 size range)
    CERTIFIED FOR: ASTM F1952 DH MTB, ASTM F2032 BMX, CPSC 1203, CE N1078, AS/NZS 2063
Composite D4 Options
D4 Composite Helmet Technical Specs (MSRP $399)
  • Aerospace composite shell
  • Lightest Composite DH/BMX Race helmet we have ever built 1050g (+/- 50g and Size M)
  • MIPS C2 brain protection system-protects against rotational impacts
  • Front air intake system with high flow-through polymer center grille and power grid side mesh
  • 24 total vents: 11 front intake ports, 6 overhead intake vents that channel air on top of your head and an industry leading 7 rear exhaust ports
  • Anti-Microbial/Quick Dry XT2® Quick release contoured 3D cheek pads create an anatomically optimized fit. Separately placed X-Static® & XT2® precision fit headliner with 7 anchor points gives you optimal fit
  • EPP Collarbone impact system; a relief area reduces the forces in the center lower section of the helmet where shoulder/collarbone impacts have been known to occur
  • In-molded polycarbonate front brow and vent ports for increased impact strength
  • 40mm of vertical visor adjustment with smart-shear breakaway visor screws
  • EPP interior injected chin-bar
  • Drawstring helmet bag included
  • 3-year warranty
  • 3 Shell sizes and 3 EPS sizes, 6 total size ranges from XS-XXL (AS/NZ – 3 size range)
  • CERTIFIED FOR: ASTM F1952 DH MTB, ASTM F2032 BMX, CPSC 1203, CE N1078, AS/NZS 2063
See more https://troyleedesigns.com/pages/d4-bike-helmet
If you’re into the 2020 D3 Fiberlite, A1, A2, or Stage helmets be sure to check those out as well
