When it comes to designing beautiful bottle openers, Paragon Machine Works clearly knows a thing or two.
Paragon Machine Works has been in business since 1983. They machine parts in the USA and are probably best known for their frame building parts like their ornate dropouts or replacement derailleur hangers.
They’ve got a wide range machined pieces like this titanium bottle opener and axles that many of you may not be familiar with. The titanium openers are made from the spare titanium they have laying around after machining other pieces.
The opener also has a 15mm closed end you can use for single speed dropouts.
This BT0002 opener will set you back $24, but and have smaller ti keychain openers as well that are a bit cheaper.
They use 6/4 Titanium and ours weighed in at 33g. Since they use spare titanium pieces for these, thickness may vary. Measurements: 4.4″ long x 1.9″ wide x .2″ thick (may vary)
Check back daily throughout the month of December as we post more content in our 25 days of Sickness!
