Formula Adds Coil to the Selva MTB Fork Range – Selva C
12/12/2019 : sicklines
Formula has answered the call to add coil to their Selva fork. Check out their process and details inside.
, Formula Adds Coil to the Selva MTB Fork Range – Selva C
The Selva C coil offering is available in 29″, 27.5, and 27.5+ and features the same Selva family CTS (Compression Tuning System) with interchangable valves, rebound, lock-out, and threshold adjustment for lock-out.
The 29″ version offers 160mm of travel while the 27.5 can be 160mm or 170mm. Offset, axle to crown, and other dimensions can be viewed in the spec sheet embeded below.
There are 4 coils available (Soft, medium, firm, and super firm) and coil preload can be externally adjusted
Claimed weights ring in between 2,230g – 2,290g depending on size.
VIDEO OVERVIEW
Selva C Parts
MSRP:
$1,048 USD / 950 EUR / 821 GDB
CTS Valves can be swapped out to change the ride characteristics from Low/Mid/Hi Speed even further
Read more about the Selva C and the systems it employs like Hex Design for stiffness, IFT, specs, and more.
