Learn more about the latest OneUp offerings inside in the video. Learn more about their new 35mm oval handlebar, stem, grips, 220mm dropper seatpost, and more.
The new 220mm OneUp seatpost offering gives taller riders a much easier way to get their seatpost out of the way on descents. New handlebar matchmaker levers are also available.
Their 35mm handlebar is quite a bit different than other 35mm handlebars. They come in two rises and 800mmm width. The bar itself is oval so it provides solid stiffness front to back but has some compliance in the upward/downward position. 35mm handlebars have been known for being too stiff for some riders and this bar should solve their issues.
In addition to the oval 35mm handlebar they have a new direct mount stem that has a built in preload system with an extra bolt at the bottom of the stem which enables you to remove your starnut. In addition to that it is compatible with their EDC tools you can store in the headtube.
The grips are also new and have some nice compliance built into the structure of the grip. It secures on one side with an allen but has raised rubber at the end for comfort and better awareness of the edge.
See more details in the video above and at oneupcomponents.com
