All new Rocky Mountain Instinct Powerplay alloy platform and Altitude Powerplay alloy
12/18/2018 : toni
, All new Rocky Mountain Instinct Powerplay alloy platform and Altitude Powerplay alloy
The Instinct Powerplay will take you to the places you never thought possible. When it comes time to head out the door for that all-day ride into the alpine, you’ll be riding further and faster than ever before on what is our most versatile e-MTB yet.
Taking our Powerplay™ line up to the next level, the Instinct Powerplay integrates our powerful Dyname™ 3.0 drive system on a 29” wheeled platform for fast rolling rides and long distances. Featuring the new iWoc TRIO remote, our RIDE-9™ adjustment system, tweaked suspension kinematics, and great small-bump sensitivity, the Instinct Powerplay is perfect for the big epic rides!
Pricing & Availability
The Powerplay is now available! Please head to your local Rocky Mountain dealer to see the bikes. Regional availability may vary.
Instinct Powerplay Alloy 70: $7,999 CAD / $6,399 USD
Instinct Powerplay Alloy 50: $6,599 CAD / $5,299 USD
When we introduced the Altitude Powerplay it blew the doors off the mountain bike community as an aggressive, capable, and powerful e-MTB. It’s now available in an alloy frame so more people can experience the ride to go further and faster than ever before.
We took the Altitude’s legendary handling and ride quality, integrated a powerful drive system and created the most capable e-MTB in the market. The Dyname™ 3.0 drive system was designed in parallel with the frame, delivering ultra-short chainstays, optimized suspension kinematics, super-low center of gravity, and class-leading torque. The result is an e-MTB that actually rides like a proper mountain bike—perfect for everything from self-shuttling all mountain trails, finding flow between the descents, and squeezing in power lunch rides.
The Altitude Powerplay is now available! Please head to your local Rocky Mountain dealer to see the bikes. Regional availability may vary.
Altitude Powerplay Alloy 70: $7,999 CAD / $6,399 USD
Altitude Powerplay Alloy 50: $6,899 CAD / $5,499 USD
Designed in Canada, in collaboration with Propulsion Powercycle, the Dyname™ 3.0 drive system is a sleek, lightweight, and powerful electric assist that pushes the boundaries of electric bikes. Its compact, low-mounted motor allows us to design electric mountain bikes to our suspension and handling standards—with proper geometry and ideal pivot placement. The system provides class-leading torque, instant power response, and super-fast charging.
We developed our own drive system so we could maintain the geometry, handling, and ride characteristics that our bikes are known for. The other systems on the market today force frame designs to be compromised rather than seamlessly integrated like ours. Our battery is stored within the downtube of our frames and the drive system itself is nicely tucked above the bottom bracket at the base of the seat tube.
Our drive system allows for an instant, natural power response that makes for an intuitive ride thanks to an in-line torque sensor. With this sensor, the power rolls on and rolls off smoothly resulting in greater bike control from the rider. This means no more spinning out on climbs, you have the ability to soft pedal technical sections or tight switchbacks, and an overall increased level of confidence as you approach and exit corners.
• High efficiency, three-phase brushless motor provides class-leading torque
• 48v battery voltage for fast-charging and heat management in high-torque scenarios
• To prevent creaking and wear, pedaling forces are isolated from the drive system via a bottom bracket shell that is integral to the frame itself
• Increased stiffness thanks to structural motor casing
• Compact, low-profile motor design with reinforced motor casing and integrated motor-brace bashguard
• Display-free with a low-profile remote for a pure ride experience
• Bar-mounted remote displays assist level, battery level, and diagnostics; controls three assist levels and “walk” mode
• Optional ebikemotion mobile app (iOS & Android) connects via Bluetooth and provides a wide range of system customization, reach estimates, ride tracking, and more
• Available with a massive 632Wh lithium-ion battery (70 level) or 500Wh lithium-ion battery (50 level)
• Minimal drag when exceeding the motor speed or when drive system is disengaged thanks to crankset clutch and elimination of traditional e-bike gearbox
• Based on a third-generation electric drive system that’s been in development since 2010
• Strong regional dealer service support
• Wear items (BB, drive sprocket) are shop-serviceable with common shop tools
• Works with a standard Race Face bottom bracket and crankset
• Charge fast, then charge hard: ultra-fast charge times of 1 hour 40 minutes (to 80%) with the 500Wh battery, or 2 hours (to 80%) with the 632Wh battery
MODEL HIGHLIGHTS
  • Dyname™ 3.0 drive system
  • All-new iWoc TRIO remote
  • Maxxis Rekon EXO 29×2.6 tires (27.5+ compatible)
  • Fox 34 Float Performance E-Bike 140mm
  • Fox Float DPS EVOL Performance Elite rear shock
  • Maxxis Rekon EXO Tubeless Ready 29×2.6 / Maxxis Rekon EXO Tubeless Ready 29×2.6
  • SRAM 12-speed drivetrain
  • Race Face AR 30 rims
  • Instinct Powerplay alloy 70, size Medium: 52.2lbs (23.6kg)
IMPROVEMENTS OVER PREVIOUS MODEL
New model for 2019
MODEL HIGHLIGHTS
  • Rockshox Reba RL 140mm
  • Rockshox Deluxe Debonair RT
  • Sun Düroc SD37
  • Instinct Powerplay alloy 50, size Medium: 52.2lbs (23.6kg)
New model for 2019
MODEL HIGHLIGHTS
  • Fox 36 E-MTB Float EVOL Grip Performance 160mm
  • Maxxis Minion DHF WT Maxx Terra 3C Tubeless Ready 27.5 x 2.5 / Maxxis Aggressor WT EXO Tubeless Ready 27.5 x 2.5
  • Race Face AR 35 rims
  • Altitude Powerplay alloy 70, size Medium: 53.4lbs (24.2kg)
New model for 2019
FORM™ alloy
MODEL HIGHLIGHTS
  • Rockshox Yari RC 160mm
  • Rockshox Deluxe RT
  • Sun Düroc SD42 rims
  • Altitude Powerplay alloy 50, size Medium: 53.4lbs (24.2kg)
New model for 2019
FORM™ alloy
Instinct Powerplay alloy and Altitude Powerplay alloy
The Instinct and the Altitude share a lot of the same frame features, but are designed for different types of riding. The Instinct Powerplay alloy has 29″ wheels and is meant for incredibly efficient travel, while the Altitude Powerplay alloy has 27.5″ wheels making it perfect for aggressive riding.
Next generation drive system
The Dyname™ 3.0 drive system was designed from the ground up to allow true mountain bike performance, while providing class-leading torque, massive battery capacity, and an intuitive ride feel.
iWoc TRIO
The iWoc TRIO is a sleek, compact, 3-button remote that is intuitive and easy to use.
Intuitive pedal assist
An in-line torque sensor provides smooth, instant power response, making for an intuitive, natural ride with no learning curve. Get on and go.
The 48v system provides super short charge times, taking only two hours to reach 80% capacity of the available 632Wh lithium ion battery.
Frame details
• The RIDE-9™ adjustment system allows riders to quickly fine-tune their geometry and suspension with a pair of Allen keys.
• Upper idler straightens the chainline for reduced drivetrain wear
• Integral bottom bracket shell is part of the frame, not the Dyname 3.0 drive system—improving stiffness and preventing creaking or wear
• Standard PF92 bottom bracket is shop serviceable and easily replaceable
• Single-sided chainstay and seatstay pivots for a narrower rear triangle—reduces heel rub, even with Boost spacing
• Enduro MAX cartridge bearing pivots with simplified hardware
• Shock-eyelet bearings for small-bump sensitivity
• Clean and tidy: oversized downtube ports for ease of cable routing, with full-length internal dropper post routing and internal brake routing in the front triangle
• Lightweight bolt-on axle for reduced hardware complexity and extra security in e-MTB applications
• Tapered ZS44 | ZS56 headset
• Boost spacing
• 1x specific
