Alpinestars – Drop Pro Kit 2018
4/11/2018 : sicklines
Alpinestars has been improving cycling clothing for some time now. Their latest Drop Pro kit aims to take it to another level of protection for riders looking for clothing that lasts in high-wear situations.
The Drop Pro kit is designed for high-abrasion protection in key areas. No matter if you call yourself an enduro racer, mountain biker, trail bike rider, or E-bike rider the Drop Pro kit has benefits for you.
The kit features a more rugged design in high-wear spots while cycling will benefit from this additional protection in mind.
Drop Pro LS Jersey
  • Constructed from lightweight, advanced poly- fabric to promote moisture-wicking.
  • Stretch mesh on the back shoulders for fit and flexibility.
  • Open mesh insert on back panel for breathability.
  • Side pockets for convenient storage. Pocket incorporates loop label to secure keys.
  • PU reinforcements in high abrasion zones on sleeves.
  • Inner terry cloth for cleaning lenses.
  • Elongated lower back hem for extended rear coverage.
  • Reflective detailing for improved rider visibility.
  • Alpinestars’ Coolstar moisture-wicking technology avoids the build-up of sweat and helps keep rider dry and comfortable.
  • Welded wrist hems for durability.
Drop Pro Shorts
  • Constructed from lightweight, advanced poly- fabric to promote moisture wicking.
  • Ergonomically profiled PU reinforcements in high abrasion zones on thighs.
  • Hook and loop strap waist adjustment with TPR pullers.
  • Zippered side pockets and back pocket.
  • Stretch material on the crotch and back yoke, with
    strategically positioned Spandex for mobility.
  • Laser-cut front air vents for cooling airflow.
  • Flat snap connection for compatibility with alpinestars inner shorts.
  • Welded hems for durability.
Learn more at https://www.alpinestars.com/activity/cycling/
