A quick look at Dainese’s All Weather Activity line for the new season…
The AWA (All Weather Activity) collection from Dainese is purposefully designed to take you wherever you want to
go. Thanks to a unique combination of technical innovation and forward-looking design AWA apparel adapts to suit
multiple outdoor sports, activity levels, climates and weather. From the Three-layer waterproof breathable AWA 3L
Jacket designed for treacherous weather to the unique knit patterns used in the AWA Tee 4 and Zip Jersey 3 this
apparel is dedicated to providing the ultimate performance on or off the bike so you can go your own way. From the very beginning Dainese has worked with bikers at the centre of a constellation of perfectly complemented research and development strategies. Collaboration with world-class technical laboratories optimize perfectly the vision of their athletes. Dainese’s passion and commitment to safety is thus as strong as its desire for the podium.The logo says it all. The Speed Demon moves last in a definite direction, seeing things that mortals can’timagine. It’s human nature to be curious. Active-minded people thrive on letting that curiosity take them on differentadventures. And the best adventures are ones that feel limitless or necessitate ending the day when the mind and body want more. Dainese created the AWA (All Weather Activity) line to be deliberately cross functional, perched at the intersection between the body and the environment. The common enabler of the AWA line, enabling winter enthusiasts to never end the day is Dainese technology and a design philosophy for the garments to adapt to multiple outdoor pursuits, intensity levels and environmental and thermal conditions. The AWA line brings its own new style and aesthetic in Dainese’s namesake Italian style with a are that is retro-futuristic and displays inspiration sources ranging from space suits to nature.
AWA 3L Jacket
Three-layer waterproof breathable jacket designed for treacherous weather and to support light layering solutions with a versatile cross-functional outer that can be worn on and off the bike. Delivering exceptional riding comfort, the fully seam-sealed construction and Vislon Aquaguard zipper block out the
weather in even the most challenging wet and cold conditions. The ergonomically efficient athletic fit stays
snug to the body, yet allows layering in combination with the Awa Hybrid Jacket. The articulated sleeves
are expertly cut for exceptional riding freedom and feature an elasticated wrist gusset for a clean tapered
forearm fit, providing full cuff coverage while outstretched at the bars. A gentle drop tail counters dirt
spray, while a contoured hem prevents the fabric from bunching up when in the riding position. Laser cut
pit vents provide improved airflow. Designed to be worn under a helmet, the hood provides protection without compromising field of vision thanks to a low-profile design that also benefits from reduced bulk and therefore flapping when the hood is not used
FEATURES
AWA Wind Jacket
Highly-packable minimalist jacket. Windproof and showerproof, it’s ideal for carrying at all times to be prepared for any unforeseen change in the weather. Using an ultra-lightweight DWR treated fabric, this jacket stows conveniently in its own inner pocket. Reducing to a minimal pack size, it’s the perfect emergency layer for cool mountain summits, cold descents or as a backup for sudden light showers. The low-profile collar with Lycra gusset and micro-brushed lining adapts snuggly to the neck, sealing out the weather without chafing or restricting movement. The sleeves are pre-shaped with seam darts for riding comfort and to reduce any fabric flapping.
FEATURES
AWA Tee 4
The knit used in this tee differs from traditional woven fabrics, enabling precise functional construction with seamless zoning and engineered performance in key areas. The fabric features a double bi-component knit construction that uses different yarns on either side of the fabric. The hydrophilic inner surface is optimized to wick moisture away from the skin, while the hydrophobic yarn used for the outer surface dries quickly. This tee is pure AWA: engineered to be cross-functional with a crew neck and clean styling that make it work just as well off the bike as on.
FEATURES
AWA Zip Jersey 3
This long-sleeve half-zip jersey is a tribute to traditional cycling looks, recreated with modern seamless knitting technology. Knitting differs from traditional woven fabrics, enabling precise functional construction with seamless zoning and engineered performance in key areas. The fabric features a double bi-component knit construction that uses different yarns on either side of the fabric. The hydrophilic inner surfaceis optimized to wick moisture away from the skin, while the hydrophobic yarn used for the outer surface dries quickly.
FEATURES
AWA Shorts
These lighter weight shorts are designed for all-mountain rides and whatever you do once you’re off the
bike. The exceptionally stretchy fabric used enables them to be engineered for high performance without
stretch gusset and inserts, resulting in a streamlined construction and cleaner looks that are perfect for its
cross-functional purpose. Two side stash pockets with durable Vislon zippers provide abundant storage.
The bottom hem is slightly shorter at the back for pedaling comfort and longer at the front to avoid any
skin gaps when knee pads are worn.
FEATURES
