Oh, this is definitely not a new standard…
The folks have SRAM have dropped an all new crank and BB system aimed at optimizing the balance between weight, stiffness, and bearing life all while being agnostic to frame design. With 7 new crank sets and 8 BB types to fit pretty much any frame on the market, unless that bike happens to be a DH rig. There are no DH level cranks supported in DUB just yet. There’s a lot to take in, including a claimed 78g weight loss in a 175 mm XX1 crank with 32t chainring and BB which makes it ever so slightly lighter than an equally spec’d Race Face Next SL G4. Full details below…
Forward thinking and backwards compatible SRAM DUB™ BB/Crank technology is the workhorse without restraint. Designed for the most discerning pros. And riders who set it and neglect it. DUB™ is compatible with all major bottom bracket standards. Offering better sealing than ever before, without having to make compromises to fit all frames. Yet it opens the door for a new crank spindle for the world’s all-time lightest crank set. It’s a new approach that embraces the old. And it’s about time.
True competitors are always looking for a performance advantage — a relentless pursuit of equipment that is lighter, stiffer, stronger and more durable. To create the best drivetrain possible, we re-examined and re-engineered our crankset design. Our all-new XX1 Eagle™ CARBON TUNED™ crankset is our lightest, stiffest and strongest to date. SRAM DUB™ technology enhances this by simplifying the relationship of the spindle to the bottom bracket, and redefining the measure of durability. DUB™-powered cranksets mean simplicity, compatibility and durability.
FEATURES/BENEFITS
DUB™ technology delivers the lightest, stiffest,
strongest crankset available
All-new SRAM CARBON TUNED™ crank technology
provides extreme stiffness and light weight
The X-SYNC™2 chainring provides significantly
quieter performance, with better mud clearing and
extraordinary durability
MSRP PRICE
$515 – $525 | €570 – €585 | £510 – £520
We know you have a lot of choices when choosing a crankset, and your choice says a lot about your personal style. We designed the new X01 Eagle™ crankset for riders who feel most stylish when they stand on top of the podium. This is a completely reengineered design, employing our proprietary CARBON TUNED™ lay-up technology. Built tough, to handle aggressive lines through rock gardens and big hits wherever you find them. The new X01 Eagle™ is our best, toughest and most aggressive Trail and Enduro crankset thanks to SRAM DUB™ technology, which features a better-engineered bottom bracket and a new spindle design. Together, these allow for a more uniform approach to bottom bracket fitment, better sealing against contamination—and define a new measure of durability. If you’re into that kind of thing.
FEATURES/BENEFITS
DUB™ technology delivers the strongest, stiffest, lightest crankset available
SRAM CARBON TUNED™ crank technology provides extreme stiffness and light weight
MSRP PRICE
$485 – $495 | €540 – €550 | £480 – £490
The SRAM GX Eagle™ crankset delivers consistent performance every time out. Featuring SRAM’s X-SYNC™2 tooth profile chainring, the GX crankset is engineered for complete chain control. Each tooth’s thickness is precisely toleranced and controlled to work seamlessly with the chain’s inner and outer links. SRAM DUB™ technology features a better-engineered bottom bracket and a new spindle design. Together, these allow for a more uniform approach to bottom bracket fitment, better sealing against contamination and forward and backward compatibility. Now everyone can benefit from a new measure of durability.
FEATURES/BENEFITS
Optimized 7000 series forged aluminum arms
DUB™ technology features a uniform approach to bottom bracket fitment, better sealing against contamination and is forward and backward compatible
MSRP PRICE
$135 – $185 | €150 – €205 | £135 – £185
The svelte strength of carbon fiber with the swagger of heavy metal. The Descendant carbon crankset uses a proprietary TRUVATIV carbon construction process that delivers a crankset light enough for XC, yet bold and badass enough for Enduro. Style and substance – Descendant. SRAM DUB™ technology features a better-engineered bottom bracket and a new spindle design. Together, these allow for a more uniform approach to bottom bracket fitment, better sealing against contamination and forward and backward compatibility. Now everyone can benefit from a new measure of durability.
FEATURES/BENEFITS
Carbon construction for lightweight durability
Fully compatible with any 1x drivetrain
MSRP PRICE
$260 | €290 | £255
The Descendant 6K crankset delivers consistent performance every time out. Featuring SRAM’s X-SYNC™2 tooth profile chainring, the Descendant crankset is engineered for complete chain control. Each tooth’s thickness is precisely toleranced and controlled to work seamlessly with the SRAM chain’s inner and outer links. SRAM DUB™ technology features a better-engineered bottom bracket and a new spindle design. Together, these allow for a more uniform approach to bottom bracket fitment, better sealing against contamination and forward and backward compatibility. Now everyone can benefit from a new measure of durability.
FEATURES/BENEFITS
Optimized 6000 series forged aluminum arms
MSRP PRICE
$105 | €115 | £105
We designed the new STYLO Carbon crankset for riders who feel most at home when riding endless single track. This is a completely new crankset, employing our proprietary layup technology. Built tough, to handle lines through rock gardens and trail, the new STYLO Carbon is strong, stiff and light. Combined with the new SRAM Eagle™ direct mount chainrings, and as a compatible crankset to the Eagle™ drivetrain. SRAM DUB™ technology features a better-engineered bottom bracket and a new spindle design. Together, these allow for a more uniform approach to bottom bracket fitment, better sealing against contamination and forward and backward compatibility. Now everyone can benefit from a new measure of durability.
FEATURES/BENEFITS
Proprietary carbon layup technology
MSRP PRICE
$260 – $310 | €290 – €345 | £255 – £305
The STYLO 6K crankset delivers consistent performance every time out. Featuring SRAM’s X-SYNC™2 tooth profile chainring, the STYLO crankset is engineered for complete chain control. Each tooth’s thickness is precisely toleranced and controlled to work seamlessly with the SRAM chain’s inner and outer links. SRAM DUB™ technology features a better-engineered bottom bracket and a new spindle design. Together, these allow for a more uniform approach to bottom bracket fitment, better sealing against contamination and forward and backward compatibility. Now everyone can benefit from a new measure of durability..
FEATURES/BENEFITS
MSRP PRICE
$105 | €115 | £105
SPECIFICATIONS
XX1 EAGLE™ DUB™ SL Crankset | X01 EAGLE™ DUB™ Crankset | GX EAGLE™ DUB™ Crankset | Descendant Carbon DUB™ Crankset | Descendant 6K DUB™ Crankset | STYLO Carbon DUB™ Crankset | STYLO 6k DUB™ Crankset | |
Variants | BOOST™, FAT 4, FAT 5 | BOOST™, FAT 4, FAT 5 | BOOST™, FAT 4, FAT 5 | BOOST™ | BOOST™ | BOOST™, FAT 4, FAT 5 | BOOST™ |
Weights | 422g* (175mm, 32t) | 471g* (175mm, 32t) | 621g (175mm, 32t) | 555g* (175mm, 32t) | 717g (175mm, 32t) | 555g* (175mm, 32t) | 705g (175mm, 32t) |
Technologies | X-SYNC™2, BOOST™, CARBON TUNED™, Eagle™ | X-SYNC™2, BOOST™, CARBON TUNED™, Eagle™ | X-SYNC™2, BOOST™, Eagle™ | X-SYNC™2, BOOST™, Eagle™ | X-SYNC™2, BOOST™, Eagle™ | X-SYNC™2, BOOST™, Eagle™ | X-SYNC™2, BOOST™, Eagle™ |
Speeds | 12 | 12 | 12 | 12 | 12 | 12 | 12 |
Compatibility | All levels of Eagle™ drivetrain systems, All major bottom bracket standards. | All levels of Eagle™ drivetrain systems, All major bottom bracket standards. | All levels of Eagle™ drivetrain systems, All major bottom bracket standards. | All levels of Eagle™ drivetrain systems, All major bottom bracket standards. | All levels of Eagle™ drivetrain systems, All major bottom bracket standards. | All levels of Eagle™ drivetrain systems, All major bottom bracket standards. | All levels of Eagle™ drivetrain systems, All major bottom bracket standards. |
Materials | Crank arm: Carbon Chainring: Aluminum CNC Eagle™ SL | Crank arm: Carbon Chainring: Aluminum CNC Eagle™ | Crank arm: 7000 series forged aluminum Chainring: Aluminum cold forged Eagle™ |
Crank arm: Carbon Chainring: Aluminum cold forged Eagle™ | Crank arm: Aluminum Chainring: Steel stamped Eagle™ ring | Crank arm: Carbon Chainring: Aluminum cold forged Eagle™ | Crank arm: Aluminum Chainring: Steel stamped Eagle™ ring |
Hardware | Direct mount | Direct mount | Direct mount | Direct mount | Direct mount | Direct mount | Direct mount |
Key Features | All-new chainring technology is designed specifically for Eagle™ chains and drivetrains | All-new chainring technology is designed specifically for Eagle™ chains and drivetrains | All-new chainring technology is designed specifically for Eagle™ chains and drivetrains | All-new chainring technology is designed specifically for Eagle™ chains and drivetrains | All-new chainring technology is designed specifically for Eagle™ chains and drivetrains | All-new chainring technology is designed specifically for Eagle™ chains and drivetrains | All-new chainring technology is designed specifically for Eagle™ chains and drivetrains |
Options | 170mm, 175mm | 170mm, 175mm | 165mm, 170mm, 175mm | 170mm, 175mm | 170mm, 175mm | 170mm, 175mm | 170mm, 175mm |
SRAM DUB™ is the single replacement for 30mm and 24mm BB spindles options
DUB™ bottom brackets fit all frame shell standards
DUB™ does NOT introduce any new frame shell standards
MSRP PRICE
$38 – $50 | €38 – €52 | £32 – £44
SPECIFICATIONS
DUB™ BSA Bottom Bracket |
DUB™ PressFit Bottom Bracket |
DUB™ BB30 Bottom Bracket |
DUB™ PressFit 30 Bottom Bracket |
BB-Frame interface |
English/BSA (100mm), English/BSA (73mm) |
PressFit (MTB: 121mm), PressFit (MTB: 89/92mm) |
BB30 | PF30 (68-92mm) |
Variants | MTB 73, MTB 68SP, MTB 73 E, MTB 100 | MTB 89.5, MTB 92, MTB 121 | MTB 73 | BB DUB PF30 MTB73 |
Weights | 76g | 71g (92mm) | 82g | 89g |
Compatibility | Threaded BSA frame shell standards | PF 92 and PF 89.5 frame shell standards | BB30 frame shell standards | PressFit 30 frame shell standards |
Cup Material | Aluminum | Steel | Aluminum | Aluminum |
