13
2018 RockShox Pike, Lyrik, RS-1, Revelation
4/13/2017 : sicklines
RockShox has released details on their revised Pike. Details inside from RockShox.
IN 2013, PIKE CREATED A NEW CATEGORY OF FORKS, AND EVER SINCE HAS BEEN HAILED AS “THE BENCHMARK”.
SO WHAT DID WE NEED TO CHANGE ON IT? EVERYTHING. MEET THE ALL NEW PIKE.
CHARGER 2 DAMPER
The evolution of the acclaimed Charger, RockShox’s most advanced damper, brings a whole new level of performance and refinement for each intended use. The new damper design provides a wider range of low speed compression adjustment in the Open mode, with a more usable Pedal setting that excels on rolling trails. The Firm setting on Pike and Lyrik has been re-tuned, and remote options with OneLoc provide on-the-fly access to the Firm mode and are an excellent match with RockShox Deluxe, Super Deluxe and Super Deluxe Coil remote rear shocks.
Featured on: MY18 Pike, Lyrik
DEBONAIR
A larger negative air spring resulting in plusher suspension. An intuition born on RockShox’s rear shocks back in 2014 is now a benchmark for superior small bump and traction performance. No longer only reserved to rear shocks, RockShox’s DebonAir air springs complement the trail smoothing performance of many forks in our product range. And while incredibly smooth in the first 1/3 of travel, DebonAir forks and shocks still provide the consistent mid-stroke support that riders know and love.
Featured on: MY18 Pike, Lyrik, Revelation, Yari
THE BENCHMARK, REDEFINED
Pike has redefined the standard by which all trail and enduro forks are judged, and is poised to keep doing so for many years to come with a completely new chassis, which enables a weight reduction of almost 150g. A new Charger 2 damper is now compatible with RockShox’s OneLoc remote for on-the-fly compression adjustments, and a perfect match to Deluxe and Super Deluxe rear shocks. The new DebonAir air spring enhances small bump sensitivity and mid-stroke support. Pike’s travel options are up to 160mm for 27.5” and 140mm for 29” with room for tires up to 2.8” on both models.
PIKE RCT3 – RCT REMOTE
The new RCT3 Charger 2 damper provides a wider range of low speed compression adjustment in the Open mode, while the Pedal mode has been re-tuned for excellent trail support. The firm setting has also been re-tuned to better match RockShox rear shocks, with OneLoc compatibility which allows on-the-fly suspension control.
Availability: April 2017
MSRP: 875-1000$, 970-1100€, 825-940£
__
THINGS TO REMEMBER
All-new lighter chassis with signature Pike stiffness
New Charger 2 damper with OneLoc remote options
New DebonAir air spring for increased small bump sensitivity and mid-stroke support
2.8” maximum tire compatibility for both 27.5” and 29” models (27.5”x3.0” tires fit in the 29” model)
Updated air pressure guide maximizes performance for E-MTB applications
__
FEATURES AND BENEFITS
External rebound damping adjustment
Low speed compression adjustment in open mode
RCT3: 3-position compression adjustment (open/pedal/firm)
RCT Remote: 2-position compression adjustment (open/firm) via OneLoc remote
180mm direct brake mount
__
USAGE
TR
EN
__
TECHNOLOGIES
CHARGER 2 DAMPER
ONELOC
DEBONAIR™
DUAL POSITION AIR
BOOST™
MAXLE ULTIMATE/STEALTH™
TORQUE CAPS™
SAG GRADIENTS
AIR GUIDES
RAPID RECOVERY SYSTEM
BOTTOMLESS TOKENS
PIKE RC – RC REMOTE
Pike RC features the all-new Charger 2 damper in a mean and lean package, with Pike’s trademark stiffness and ride quality. The DebonAir air spring ensures excellent small bump sensitivity and mid-stroke support, and OneLoc remote compatibility pairs excellently with new RockShox rear shocks.
Availability: OEM only
__
THINGS TO REMEMBER
__
RC: low speed compression adjustment from open to firm
RC Remote: 2-position compression adjustment (open/firm) via OneLoc remote
__
USAGE
TR
EN
__
TECHNOLOGIES
CHARGER 2 DAMPER
ONELOC
DEBONAIR™
DUAL POSITION AIR
BOOST™
TORQUE CAPS™
SAG GRADIENTS
AIR GUIDES
BOTTOMLESS TOKENS
LYRIK
Embargo: 04/13/17
Retail: 05/17
, 2018 RockShox Pike, Lyrik, RS-1, Revelation
LYRIK RCT3 – RCT REMOTE
The new Lyrik gets our new Charger 2 damper, which reduces overall weight, increases bump-sensitivity and traction, and reduces the force needed to turn knobs and lock in the best setting for the terrain. And since today’s enduro riders demand ultimate pedaling efficiency, the new Lyrik is remote compatible, which allows for on-the-fly compression control.
Availability: May 2017
MSRP: 1030-1180$, 1145-1310€, 970-1100£
__
THINGS TO REMEMBER
New Boost only chassis with 2.8” maximum tire compatibility for both 27.5” and 29” models (27.5”x3.0” tires fit in the 29” model)
__
180mm max travel for both 27.5” and 29” models
__
USAGE
EN
__
TECHNOLOGIES
CHARGER 2 DAMPER
ONELOC
DEBONAIR™
DUAL POSITION AIR
BOOST™
TORQUE CAPS™
SAG GRADIENTS
AIR GUIDES
BOTTOMLESS TOKENS
LYRIK RC – RC REMOTE
Simply put, the RockShox Lyrik is an absolute weapon for enduro riders everywhere. It makes more control at higher speeds on big burly terrain not only possible, but also addictive.
__
THINGS TO REMEMBER
__
__
USAGE
TR
__
TECHNOLOGIES
CHARGER 2 DAMPER
ONELOC
DEBONAIR™
DUAL POSITION AIR
BOOST™
TORQUE CAPS™
SAG GRADIENTS
AIR GUIDES
BOTTOMLESS TOKENS
REVELATION
Embargo: 04/13/17
Retail: 05/17
REVELATION RC
Revelation has grown. After many years as the original long travel trail fork, the new Revelation is ready to tackle the most demanding trail and enduro rides. The chassis is directly derived from the new Pike, with 35mm upper tubes for unmatched stiffness and to pair with the aggressive look of modern trail and enduro bikes.
MSRP: 650-720$, 720-800€, 610-680£
YARI
Embargo: 04/13/17
Retail: 05/17
YARI RC
Yari brings Lyrik’s acclaimed look and proven features, such as the 35mm chassis, Fast Black upper tubes and DebonAir or Dual Position Air™ spring systems, to a wider audience. The refined Motion Control IS damper features Rapid Recovery rebound and its high speed compression circuit is tuned to match the feeling of the Charger damper.
MSRP: 700-780$, 780-865€, 660-735£
__
THINGS TO REMEMBER
__
Motion Control damper with low speed compression adjustment (open to lock)
OneLoc remote compatible
__
USAGE
EN
__
TECHNOLOGIES
MOTION CONTROL
ONELOC
DEBONAIR™
DUAL POSITION AIR
BOOST™
TORQUE CAPS™
SAG GRADIENTS
AIR GUIDES
BOTTOMLESS TOKENS
RS-1
Embargo: 04/13/17
Retail: 04/17
CHARGER 2 – RS-1 AND SID
The evolution of the acclaimed Charger, RockShox’s most advanced damper, brings a whole new level of performance and refinement for each intended use, with an XC focused version developed for SID and now also available on RS-1.
The damper design on SID and RS-1 features a Lock mode that is rock-solid for maximum pedaling efficiency. Remote options with OneLoc provide on-the-fly access to the lock and are an excellent match with RockShox Deluxe rear shocks.
Featured on: MY18 RS-1, SID (from MY17 onwards)
RS-1 RLC
Designed with a cross-country-first focus, riders around the world insisted that the RS-1 had great potential as a trail fork. The new RS-1 spreads its wings with the all new Charger 2 damper™, which provides unmatched-in-class small bump traction and a much more defined lockout — and is available in new 130mm (27.5”) travel options.
MSRP: 1680$, 1865€, 1580£
__
THINGS TO REMEMBER
New 130mm travel option for 27.5” chassis
New graphics
__
2 position compression (open/lock) with low speed compression adjustment in open mode
__
USAGE
XC
TR
__
TECHNOLOGIES
CHARGER 2 DAMPER
SOLO AIR
BOOST™
MAXLE ULTIMATE
PREDICTIVE STEERING
SAG GRADIENTS
AIR GUIDES
BOTTOMLESS TOKENS
RS-1 RL
A quarter-century after revolutionizing the sport of mountain biking with the world’s first highly adopted suspension fork, RockShox handed the legendary RS-1 name to a new breed of fork. The new RS-1 RL utilizes the OneLoc remote, making it a perfect match for RockShox Deluxe rear shocks.
MSRP: 1750$, 1945€, 1650£ (includes OneLoc remote)
__
THINGS TO REMEMBER
New Charger 2 damper compatible with OneLoc remote
New graphics
__
2 position compression (open/lock) via OneLoc remote
__
USAGE
XC
TR
__
TECHNOLOGIES
CHARGER 2 DAMPER
ONELOC
SOLO AIR
BOOST™
MAXLE ULTIMATE
PREDICTIVE STEERING
SAG GRADIENTS
AIR GUIDES
BOTTOMLESS TOKENS
See more at www.sram.com
