RockShox Judy Returns : Gold RL, Silver TK and New Super Deluxe Rear Shocks Air / Coil – 2017/2018 (29″ 27.5)
3/22/2017 : sicklines
RockShox is bring the Judy back. While the name is back, the product is updated quite a bit. Details inside from RockShox.
JUDY – SHE’S BACK! AND SHE’S READY FOR THE FUTURE
PLUS FUN & PLUS CONTROL, FOR ALL
Who says entry level bikes can’t get all the latest features and performance? Judy is built around a brand new chassis, designed with the same philosophy of the award-winning Pike for the demands of modern mountain biking: stiff, yet very light. Boost™ means room for Plus tires, up to 2.8” in both the 27.5” and 29” models, while Torque Cap compatibility adds additional stiffness and steering precision.
JUDY GOLD RL
Bringing a legendary name forward, Judy Gold is definitely ready for the future with 2.8” tire compatibility in both 27.5” and 29” version. It’s also packed full of trail tech with Motion
Control™ RL damping, OneLoc remote compatibility and Fast Black upper tubes for that
unmistakable RockShox look and performance.
THINGS TO REMEMBER
• 2.8” maximum tire compatibility for both 27.5” and 29” models (27.5”x3.0” tires fit in the 29” model)
• All new Boost™-specific chassis: light yet stiff
• New low profile integrated remote spool
• New air pressure guide maximizes performance for E-MTB applications
FEATURES AND BENEFITS
• 80-120mm travel
• Fast Black aluminum upper tubes
• Performance-based Motion Control™ RL damper
• Compatible with OneLoc remote
• Easy to set up Solo Air spring
USAGE
XC
TR
TECHNOLOGIES
MOTION CONTROL™
ONELOC
SOLO AIR™
BOOST™
MAXLE LITE/STEALTH™
TORQUE CAPS™
Availability: April 2017
MSRP: 380-450$, 420-500€, 360-425£
JUDY SILVER TK
Judy Silver brings the benefits of Boost™ to bold new places with 2.8” tire compatibility in both 27.5” and 29” versions, and delivers proven RockShox technologies such as the Solo Air™ spring and the easy to use TurnKey™ damper with lockout.
THINGS TO REMEMBER
• Steel upper tubes with Satin Nickel finish
• 80-120mm travel
• Proven TurnKey™ damping
• PopLoc remote compatible
• Lightweight Solo Air™ spring
USAGE
XC
TR
TECHNOLOGIES
POPLOC
TURNKEY™
SOLO AIR™
BOOST™
MAXLE LITE/STEALTH™
TORQUE CAPS™
Availability: OEM only
RECON RL
Recon combines Reba’s light weight and Sektor’s stiff chassis with bombproof RockShox steel upper tubes, growing in travel options up to 150mm in 27.5”. And with the addition of its now-standard Motion Control™ RL damper, the re-invented Recon is the new gold standard for fun.
THINGS TO REMEMBER
• Two chassis versions: 120mm and 150mm max travel
• 27.5” and 29” Boost™ versions
• Remote version is compatible with OneLoc remote
• Updated air pressure guide maximizes performance for E-MTB applications
• 80-120mm and 130-150mm travel
• Efficient Motion Control RL damper
• Easy to set Solo Air spring
USAGE
XC
TR
TECHNOLOGIES
MOTION CONTROL™
ONELOC
SOLO AIR™
BOOST™
MAXLE LITE/STEALTH™
MSRP: 250-320$, 280-355€, 235-300£
SID RL
A dedicated, 100 millimeter travel-specific chassis, damper and air spring, precise steering characteristics, and an unmistakable every-gram-counts attitude — each element of SID’s design is focused on winning. The RL model brings Charger 2 damper performance for an unbelievable value.
THINGS TO REMEMBER
• New RL version of Charger 2 damper
• Cable remote option compatible with OneLoc remote
• New graphics
• Available in Boost™ and 15×100
• 80-100mm travel
• Firm lockout tune
• Solo Air™ spring
• Ultralight SID chassis
USAGE
XC
TECHNOLOGIES
CHARGER 2 DAMPER
ONELOC
SOLO AIR™
BOOST™
MAXLE LITE/STEALTH™
TORQUE CAPS™
SAG GRADIENTS
AIR GUIDES
RAPID RECOVERY SYSTEM
BOTTOMLESS TOKENS™
Availability: May 2017
MSRP: 600-670$, 665-745€, 565-630£
REBA RL
Reba has always signified RockShox quality and performance. Even more so now, with new chassis options that allow Reba to be a frontrunner in any role, from XC to trail riding. With technologies developed in SID, Reba and Revelation, Reba is the one-stop solution to
everyone looking for the unmistakable RockShox performance in a proven package.
THINGS TO REMEMBER
• Three chassis versions: 100, 120 and 150mm max travel
• 27.5” Plus tire compatible on 29” Boost™ chassis
• Updated low profile air spring caps with cassette tool interface
• for E-MTB applications
• 80-100mm, 120mm and 130-150mm travel versions
• Motion Control RL damper
• Tapered steerer, 15mm Maxle
USAGE
XC
TR
TECHNOLOGIES
MOTION CONTROL™
ONELOC
SOLO AIR™
BOOST™
MAXLE LITE / STEALTH™
AIRGUIDES
BOTTOMLESS TOKENS™
SAG GRADIENTS
AIR GUIDES
TORQUE CAPS™
MSRP: 500-570$, 555-635€, 470-535£
DECAL PACKS
Aftermarket decal packs in 9 different color options:
Stealth, Yellow, Orange, Red, Green, Blue, Magenta, Grey and White.
Three chassis options:
– 30/32mm upper tube forks and RS-1
– 35mm upper tube single crown forks
– 35mm dual crown forks
All include pill logos to match rear shocks.
Availability: April 2017 (dealers and sramnation.com)
MSRP: 18$, 19.64€
AM REAR SHOCKS OFFERING
DELUXE RT3
All shocks include mounting hardware:
– 2017 Giant Anthem – Deluxe RT3 (165×42.5) – 410$, 455€, 545£
DebonAir, 2 Tokens, MReb/MComp, Soft Pedal, 380lb Lockout Force, Trunnion upper mount
– 2017 Trek Fuel EX – Deluxe RT3 (210×52.5) – 410$, 438€, 371£
DebonAir, 2 Tokens, MReb/MComp, Firm Pedal, 380 Lockout Force, hardware for alloy and carbon models
SUPER DELUXE
– 2017 Giant Trance – Super Deluxe RCT (185×55) – 575$, 640€, 770£
DebonAir, 2 Tokens, MReb/LComp, 380lb Lockout Force, Trunnion upper mount
– 2017 Yeti SB5 – Super Deluxe RCT (210×50) – 575$, 640€, 770£
DebonAir, 2 Tokens, MReb/LComp, 380lb Lockout Force, Standard, Bearing – includes “GNAR” token (extra air volume adjuster equivalent to 2.5 tokens)
– 2017 Remedy and Slash – Super Deluxe RC3 (230×57.5) -525$, 561€, 476£
DebonAir, High Volume Eyelet, 2 Volume Tokens, MReb/MComp, 380 lb Lockout Force
SUPER DELUXE COIL
– 2017 Norco Sight – Super Deluxe Coil RCT (185×55)- 550$, 610€, 730£
MReb/MComp, 380lb Lockout Force, Trunnion upper mount
– 2017 Transition Patrol – Super Deluxe Coil RCT (230×65)- 550$, 610€, 730£
MReb/MComp, 380lb Lockout Force, Standard, Bearing upper mount
– 2017 Commencal Meta V4.2 (230×60) – Super Deluxe Coil RT Remote – 595$, 660€, 790£ – includes OneLoc remote – EWS winning setup!
