Paul Components – Set N’ Forget Thru-Axles – 15mm, 12mm Front, 12mm Rear
11/17/2016 : sicklines
, Paul Components – Set N’ Forget Thru-Axles – 15mm, 12mm Front, 12mm Rear
Paul Comonents has some made in America thru-axles in a variety of length and anodized finishes that work with frames and forks. Check out some of the details inside from Paul Components.
A 12-position indexing head allows the lever to be set easily by pushing down on the head and rotating the lever to the desired position, the lever will then always close in that intended position without loosening or vibrating out of form. No more snagging on bushes and branches nor interfering with your frame/fork. Thru-axles come in 9 different lengths, two different diameters, and two different thread pitches.
The Set N’ Forget was born out of the need for a high-quality, reliable, simple, and effective thru-axle quick release as commercial TAQRs are fragile, plastic, and poorly designed. Paul Components engineering and craftsmanship has made themselves a household name in the cycling community due to the quality, feel, and precision of everything they make.
Specs:
Material: Stainless Steal, 7075 and 6061 Aluminum
Weight: Varies with size
Anodized Color: Black, Silver, Orange (head only)
Cam: Internal
Learn more at paulcomp.com
