Yeti showed us some of their newest 2017 bikes and we snapped a few detailed pictures that you can see inside. For 2017 they’re offering TURQ series and Carbon series bikes. Learn more inside.
The main difference you’ll see on the TURQ series bikes is not easy to spot from the outside. While the build spec’s are higher on TURQ models, the real tweaks are to the carbon layup. Compared to their standard Carbon models, TURQ shaves 250-400g. EWS tested and proven.
Carbon series frames while still high quality utilize less high modulus carbon than the TURQ Series bikes. The Carbon Series maintains Yeti’s award winning ride quality and technology standards only sacrificing weight. Every model in their lineup now includes Carbon Series frames paired with individually chosen components to balance performance and price.
Be sure to read more about their 2017 range and clothing in our earlier post as well.
The Yeti SB5 features internal cable routing. The black plate you see in the downtube helps you route the seatpost dropper cable. Additional detailed shots can be viewed in the gallery below.
The all-new SB5 is the next iteration of our most popular all-mountain bike. Born from the trails of Colorado, this bike represents everything a trail bike should be — lightweight, nimble on climbs and dominant on descents. With an updated, sleek frame design, internal cable routing, BOOST spacing, lower stand-over height and metric suspension all atop Yeti’s Switch Infinity translating pivot, the all-new SB5 is the go-to choice for any trail adventure.
Always reaching for the widest tire you can find? If so, push your limits on Yeti’s all-new plus bike, the SB5+. Offering unparalleled stability and traction, the SB5+ offers 5 inches of travel, resulting in a bike equally balanced for climbs and descents. Yeti’s Switch Infinity suspension platform and smart frame design will bring ease to mucky trails, loose gravel and essentially any trail condition you can throw at this bike.
Yeti’s new 27.5 Plus sized bike uses their Switch Infinity suspension system. Available in a variety of build options.
Be sure to check the catalog for all the geometry, remaining items in the Yeti range including the SB6, SB5.5c, SB5 Beti, and more.
2017 Catalog (Geometry, ASR, SB6, SB4.5, SB5.5c, Beti models, and more)
2017 Yeti Clothing
2017 Yeti Pricing
Check out their webpage at www.yeticycles.com
