Alpinestars sent over some details on a few of their 2017 pieces. Check them out inside.
2017 Evolution Long Sleeve Jacket
Removable and replaceable Level 1 CE-certified back protector.
Multi-material streamlined design for superior body fit which enables top to be worn under jersey.
Lightweight, stretchable mesh main construction with breathable padded inserts.
Long removable sleeves with CE certified Level 1 shoulder and elbow protector (1621_1:2012).
Strategically placed panels to ensure the vest remains well fitted.
Ergonomic back protector follows natural curve of the back.
Back protector pocket can also house hydration pack.
Front and back conduits for hydration pack hose.
Rear kidney compartments for convenient access.
Full length main front zipper for easy in and out.
Soft chest and side padding is reinforced for added impact absorption and comfort.
2017 Evolution Vest
Incorporates LEVEL 2 CE certified (1621_2:2014) back protection, which is constructed from an innovative fusion of energy absorbing viscoelastic memory foam with articulated vertebrae protection
No sleeves allow for use with Alpinestars elbow protectors.
Vector DH Jersey and Pants
Stretchable poly-fabric main shell has excellent moisture-wicking and is quick-drying for optimized temperature control
Ergonomically designed for a contoured fit and easy integration with elbow and back protectors.
Mesh panels are strategically positioned under arms ensure additional airflow.
Collar incorporates Lycra® for added comfort on long rides.
