2017 Specialized Enduro 6Fattie/29er or 650B
8/14/2016 : sicklines
, 2017 Specialized Enduro 6Fattie/29er or 650B
Enduro Photos DT: Jackson Hole
Specialized has officially unveiled their new 2017 Enduro.  Learn more about it inside.
Photos:Sterling Lorence, Specialized, Harookz
For 2017, Specialized has been hard at work on this new Enduro.  They focused on handling, utility, and robust construction.  Specialized has pushed the geometry limits and this new Enduro takes things lower, slacker, and short chainstays (650b: 425mm | 29/6Fattie: 432mm).
  • 650b — 170mm fork travel and 170mm rear travel.
  • 29-inch — 160mm fork travel and 165mm rear travel.
  • Oversized Bearings & Hardware—Increased demands on bikes called for stouter bearings and hardware. The new links house larger bearings and hardware to increase bearing life and balance, as well as the handling characteristics of the chassis.
  • All linkage bearings are the same size.
  • Threaded bottom bracket (73mm)
Pricing:
  • Comp Alloy $3000
  • Elite Carbon $4400
  • Pro Carbon $6500
  • S-Works Carbon $8500
  • S-Works Frame $3500
Select models available now.
Geometry (Enduro 29/6Fattie and Enduro 650B):
Ohlins suspension partner
It’s no secret that we developed our Demo 8 with Ohlins in order to make the fastest World Cup DH bike on the market, and for the Enduro, Ohlins and our suspension team took that knowledge and experience to develop both the Enduro and the STX22 together. Gone are the days of unnecessary clicks and adjustments and poor setups. The low-hysteresis system, found here, provides unmatched control and consistency.
  • Supple low-speed compression circuit for unrivaled reaction, climbing, or descending.
  • Shock Block mounting hardware provides a stiff, responsive connection.
  • Tuned high-speed compression for more control on big hits.
  •  AUTOSAG for hassle-free set up—every time.
  • 3 clicks High Speed Compression
  • 9 clicks Low Speed Compression
  • 6 clicks Low Speed Rebound
Internal Cable Routing
  • The cables cleanly enter the head tube and follow independently molded tubes through the length of the down tube. This way, you can say goodbye to magnets, flashlights, hooks, or fighting to swap housing.
  • Cables run over the top of the threaded BB shell in order to reduce the pull/bend on the cable housing. This creates more consistent and crisper shifting.
The Enduro features SWAT. Storage, Water, Air, and Tools. Plenty of space for internal storage integrated into frame.
The Enduro uses a standard threaded 73mm bottom bracket.  You asked, they listened.
2016 Specialized Enduro SWORKS
Complete Enduro Bikes
Detailed shots of the 2017 Specialized Enduro.  Highlights include internal cable routing, threaded 73mm bottom bracket, and more.
Check out some of the pictures with the Coastal Crew, Curtis Keene, and Jared Graves shredding on the new Enduro.
2016 Specialized Enduro Launch
For more details, visit www.specialized.com
