2017 Truvativ Components: Carbon Cranks, Truvativ DH Aluminum Crankset, Carbon Handlebars, Alloy, and more
3/23/2016 : sicklines
TRUVATIV beamed over some new details on their 2017 DESCENDANT components. Learn more about them inside.
RETAIL: JUN 2016
Born from the Mountain
What matters most to hardcore mountain bikers? Performance, durability, affordability, and style. TRUVATIV’s new Descendant series serves up all of these with confidence to spare. Guided by input from some of the most talented riders in Enduro and Gravity, each component in the Descendant lineup has been built to survive mountain biking’s most aggressive riders and thrive on the world’s rowdiest trails.
DESCENDANT Crankset
, 2017 Truvativ Components:  Carbon Cranks, Truvativ DH Aluminum Crankset, Carbon Handlebars, Alloy, and more
Aggression with attitude. These forged aluminum cranks, with direct mount rings, feature the 1x benchmark SRAM X-SYNC™ tooth profile. With attitude matched only by pure performance, these cranks deliver. Meet a whole new side of the mountain—Descendant.
MSRP PRICE
$161-188 | €175-205 | £134-158
Things To Remember
Less weight with direct mount ring
Super-stiff design
Features And Benefits
7000 series forged aluminum arms
Fully compatible with any 1x drivetrain
Direct mount ring
SPECS1. BB Compatibility: BB30/PF30-68/73mm , GXP/PF GXP 68/73mm. BB Spindle Interface: 24mm, 30mm. Bolt Circle Diameter: Direct mount (DM). Chainline: 49.0mm, 52.0mm. Chain Ring: 32. Chainring Material: Aluminum?7. Color (Crank Arm): Black. Crank Arm Length: 170mm, 175mm. Crank Arm Material: Aluminum. Guard: No Guard. Speeds: 10/11
DESCENDANT Carbon Crankset
The svelte strength of carbon fiber with the swagger of heavy metal. The Descendant carbon crankset uses a proprietary TRUVATIV carbon construction process that delivers a crankset light enough for XC, yet bold and badass enough for Enduro. Style and substance—Descendant.
MSRP PRICE
$311-340 | €340-371 | £262-286
Things To Remember
Most affordable carbon crankset in the industry
Carbon construction for lightweight durability
AM STEP SPECS. BB Compatibility: BB30/PF30-68/73mm , GXP/PF GXP 68/73mm. BB Spindle Interface: 24mm, 30mm. Bolt Circle Diameter: Direct mount (DM). Chainline: 49.0mm, 52.0mm. Chain Ring: 32. Chainring Material: Aluminum. Color (Crank Arm): Black. Crank Arm Length: 175mm. Crank Arm Material: Carbon. Guard: No Guard. Speeds: 10/11
DESCENDANT DH Crankset
Model Overview
Whether your target is high speed or big air, an unwavering focus on dependability and style can never be overlooked. Blending the experience of countless DH podiums, big mountain competitions and film sessions, the new Descendant DH crank brings clock-beating weight savings to freeride burliness—at a price that will leave money for the next adventure. Meet your gravity goals—Descendant.
MSRP PRICE
$151-196 | €166-214 | £122-158
Things To Remember
Lightweight DH crank set
New graphics
World Cup proven design
X-SYNC™ chainring
SPECS
1. BB Compatibility: GXP 83mm/PF GXP 104.5/107mm, PF30 83mm
2. BB Spindle Interface: 24mm, 30mm
3. Bolt Circle Diameter: 94 BCD
4. Chainline: 57.0mm
5. Chain Ring: 34?6. Chainring Material: Aluminum
8. Crank Arm Length: 165mm, 170mm
9. Crank Arm Material: Aluminum
10. Guard: No Guard
11. Speeds: 10/11
DESCENDANT Flat Bar
Uncompromising control and unflinching style. Based on the width of Enduro superstar Jerome Clementz, the Descendant carbon and 7050 flat bars bring comfort and control to riders seeking the aggressive position a flat bar offers. Descendant series bars are the new benchmark for control and comfort.
MSRP PRICE (CARBON/ALLOY)
$150/65 | €163/71 | £126/54
Things To Remember
Stiff, precise and wide
Carbon fiber perfection or tough 7050 alloy
Descendent geometry from our best enduro rider’s input
Specs?2. Back Sweep (degrees): 7?3. Clamp Diam: 31.8?4. Color/ Finish: Black?5. Material : Carbon or Al-7050?7. Type : Flat?8. Upsweep (degree): n/a?9. Width: 750mm (Carbon), 760mm (Alloy)
DESCENDANT Riser Bar
Model Overview
Combine a proven shape, proven width, proven materials and a take-no-prisoners approach, and you’ve got the new Carbon and 7050 Descendant riser bars. They are stiff, tough, dependable, and give you all the comfort and positive steering feel you could want. Descendant series bars are the new normal for comfort and control.
Things To Remember
Descendant geometry from our best enduro rider’s input
Specs
Clamp Diam: 31.8
Rise: 20mm
Type : Riser
Upsweep (degree): 5
DESCENDANT DH Bar
Model Overview
You say you want a wide, stiff, strong, championship-winning design? Here you go. The new Descendant DH bar borrows from a rich championship-winning heritage, and adapts it to today’s aggressive courses and riders. Descendant DH bars are the command center of cornering control.
MSRP PRICE
$70 | €77 | £59
Things To Remember
Made with tough 7050 alloy
Descendent geometry from our best DH/Gravity rider’s input
Specs
Application: Freeride/Downhill
Back Sweep (degrees): 9
Clamp Diam: 31.8
Material : Al-7050
Rise: 25mm
Type : Riser
Upsweep (degree): 5
Width: 800mm
DESCENDANT DH Seatpost
Model Overview
Set it and forget it. The most important attribute of a DH seatpost is that you forget it’s there—until you need it to be there. The 3D forged and highly adjustable Descendant DH seatpost is built to simply do its job so that you can do yours. Set it, forget it, and go harder.
Things To Remember
Made with a tough 7050 alloy
Easy-to-adjust dual bolt head design
Zero offset
Tough and light
Forged and butted 7050 shaft
Forged seat clamps
Clamp Material: Al-7050
Hardware: Steel
Material: Al-7050
Offset/Setback: 0mm
Post Diameter: 30.9mm, 31.6mm
Length: 350mm
DESCENDANT Seatpost
Model Overview
Set it and forget it. The most important attribute of a fixed seatpost is that you forget it’s there—until you need it to be there. The 3D forged and highly adjustable Descendant seatpost is built to do its job so that you can do yours. Set it, forget it, and go harder.
Things To Remember
Zero offset
Tough and light
Forged seat clamps
Hardware: Steel
Material: Al-7050
Offset/Setback: 0mm
Length: 400mm
DESCENDANT Stem
Model Overview
Mix and Match might work for clothing, but not your mountain bike cockpit. The new Descendant stem is 3D forged from 7050 alloy, then machined for weight reduction, and is the perfect match for your Descendant bars—not that you’re worried about that kind of thing. Built strong, to take on the world’s toughest trails, Descendant stems keep you pointed in the right direction.
Things To Remember
Perfect match with Descendant handlebars
3D forged 7050
CNC machined for weight reduction
Four bolt handlebar clamp
Two bolt steerer clamp
Strength and weight
The right spec for trail and enduro
Clamp diam: 31.8mm
Color/finish (ST): Black
Hardware: Steel
Length (ST): 40mm, 50mm, 60mm
Material (SP/ST): Al-7075?Steerer clamp diameter: 1-1/8 in?Stem angle/rise: 0 degrees
www.truvativ.com
