2016 SRAM NX 1x DRIVETRAIN
2/18/2016 : sicklines
, 2016 SRAM NX 1x DRIVETRAIN
SRAM sent over some details on their new NX 1X drivetrain. Learn more about it inside.
SRAM NX : START WITH ONE
It’s how you start that matters. Whether you’re discovering the mountain for the first time or you’re an MTB lifer searching for a no-nonsense, no-worries 1x drivetrain, SRAM NX is ready for action and ready to take you there. NX brings you a wide range of gear choices engineered for simplicity and durability, so you can focus on what matters most—the ride ahead. German engineered and proudly bearing the SRAM 1x™ stamp of approval, NX is ready to let the world know what real riding feels like. START NEW.
START RIGHT. START WITH SRAM NX.
USAGE XC TRail ENduro
__________________________________
1x X-SYNC™ CRANKSET
Overview
The SRAM NX crankset provides high performance at the right price. Featuring the SRAM engineered X-
SYNC™ chainring, the NX crankset is engineered for complete chain control. Each tooth’s thickness is
CNC machined to work seamlessly with the chain’s inner and outer links.
MSRP PRICE
  • $116 | €120 | £92
Features and Benefits
  • 6000 series aluminum arms
  • Fully compatible with all SRAM 1x™ drivetrains
  • Most affordable fully featured 1x crank in the industry
  • Usage: XC, TR, EN
  • Technologies: X-SYNC™, GXP, BB30
Specifications
  • Speeds 11
  • BB Compatibility :BB30/PF30-68/73mm, GXP 100mm/ PF GXP 121mm, GXP PF GXP 68/ 73mm
  • Chainring compatibility: 28t, 30t, 32t, 34t, 36t, 38t, 40t
  • CRANK ARM LENGTH: 155mm, 165mm, 170mm, 175mm
  • COLOR (CRANK ARM): Black
  • BB SPINDLE INTERFACE : 24mm, 30mm
  • CHAINRING MATERIAL :Aluminum
  • GUARD: Aluminum Guard, No Guard
  • BOLT CIRCLE DIAMETER (BCD): 94 BCD
  • CRANK ARM MATERIAL: Aluminum
  • CHAINLINE: 49.0mm, 52.0mm, 66.5mm
  • PART WEIGHT: 680-780g
1×11 X-HORIZON™ REAR DERAILLEUR
OVERVIEW
The SRAM NX X-HORIZON™ rear derailleur provides the same smooth, reliable shifting action as
XX1—from the larger upper pulley offset to the 12-tooth X-SYNC™ pulley wheels. By eliminating
unwanted chain movement, X-HORIZON™ shifts faster, puts an end to ghost shifting and reduces shift
force and chain slap. And with CAGE LOCK™ technology, wheel removal and installation are easier than
ever.
MSRP PRICE
  • $74 | €76 | £58
FEATURES AND BENEFITS
  • X-HORIZON™ design that reduces shift force, ghost shifting and chain slap
  • 12-tooth X-SYNC™ pulley wheels
  • Most affordable fully featured 1x rear derailleur in the industry
TECHNOLOGIES
  • X-HORIZON™
  • X-SYNC™
  • X-ACTUATION™
  • CAGE LOCK™
  • ROLLER BEARING CLUTCH™
SPECIFICATIONS
  • SPEEDS 11
  • CABLE PULL RATIO: X-ACTUATION™
  • CAGE: Long
  • MAX TOOTH: 42
  • COLOR: Black
  • PULLEY BEARINGS MATERIAL: Steel
  • CAGE MATERIAL: Steel
  • PART WEIGHT: 322g
11-SPEED X-ACTUATION™ TRIGGER SHIFTER
OVERVIEW
SRAM NX trigger shifter with X-ACTUATION™ technology gives you sharp, dependable shifting. Built for
precise and swift shifting across our wide range 11-speed cassette, the NX trigger shifter brings industry
changing technology to everyone.
MSRP PRICE
  • $27 | €28 | £22
  • X-ACTUATION™ for precise and dependable 11-speed performance
___
TECHNOLOGIES
  • X-ACTUATION™
SPECIFICATIONS
  • SPEEDS 11
  • COMPATIBILITY 11-speed rear derailleur
  • CABLE PULL RATIO X-ACTUATION™
  • COLOR Black
  • CABLE LENGTH 2200mm
  • SHIFTER TYPE Trigger
  • MATCHMAKER COMPATIBLE No
  • CLAMP INCLUDED Yes
  • MAX UPSHIFTS 5
  • PULL LEVER ADJUST No
  • MULTI-POSITION No
  • GEAR INDICATION No
  • PART WEIGHT 142g
_______________________________________________
11-SPEED X-ACTUATION™ GRIP SHIFT
OVERVIEW
SRAM NX Grip Shift with X-ACTUATION™ technology gives you sharp, dependable shifting. Built for
precise and swift shifting across our wide range 11-speed cassette, the NX Grip Shift brings industry
MSRP PRICE
  • $33 | €35 | £26
__
  • SRAM 1x™ X-ACTUATION™ for precise and dependable 11-speed performance
  • SPEED METAL™ shift indexing
  • ROLLING THUNDER™ ball bearing technology
  • JAWS™ lock-on grip technology
  • Most affordable fully featured 1x grip shifter in the industry
TECHNOLOGIES
  • X-ACTUATION™
  • SPEED METAL™
  • ROLLING THUNDER™
  • JAWS
SPECIFICATIONS
  • SPEEDS 11
  • COLOR Black
  • SHIFTER TYPE Twist
  • MAX UPSHIFTS n/a
  • PULL LEVER ADJUST n/a
  • MULTI-POSITION No
PC-1110 CHAIN
OVERVIEW
Designed from a long line of dependable, lightweight chains that are built for toughness, the
recommended chain for NX, PC-1110. Designed with SRAM’s trusted XX1 geometry, the PC-1110
features solid pin construction, 11-speed PowerLock® and smooth, efficient shifting that you can count
on every time out.
MSRP PRICE
  • $14 | €14 | £11
  • Optimized to work with X-SYNC™ rings for precise and dependable 11-speed performance
TECHNOLOGIES
  • X-SYNC™
SPECIFICATIONS
  • COMPATIBILITY—SPEED 11
  • CHAIN LENGTH 114 links
  • COLOR—OUTER LINK Grey
  • COLOR—INNER LINK Grey
  • CHAIN CONNECTOR PowerLock®
  • INNER LINK FINISH Polished
  • OUTER LINK FINISH Polished
  • PIN VARIANT Solid Pin
  • PIN TREATMENT Chrome Hardened
  • PART WEIGHT 232-273g
PG-1130 CASSETTE
OVERVIEW
The PG-1130 cassette is light, durable and equipped with SRAM’s super wide 11-42t gear range that’s a
perfect fit for any ride. Personalize your wide range gearing with one of eight available X-SYNC™
chainrings.
__
MSRP PRICE
  • $79 | €89 | £68
__
  • Super wide gear range—a perfect fit for any ride
  • Optimized gear steps across entire range
  • Compatible with non XD™ driver body
SPECIFICATIONS
  • SPEED 11
  • GEARING 11-42t
  • COG FINISH Black
  • TECHNOLOGY PG
  • COG SIZES 11t, 13t, 15t, 17t, 19t, 22t, 25t, 28t, 32t, 36t, 42t
  • COGS ON CLUSTER 3
  • PART WEIGHT 538g
TECHNOLOGIES
X-HORIZON™
The X-HORIZON™ rear derailleur’s ‘straight parallelogram’ design limits all movement to the horizontal
axis, which makes ghost shifting impossible while also reducing shift force. For quicker, more exact
shifting, the large upper pulley offset design maintains a constant chain gap across all gears.
DERAILLEUR MOVEMENT LIMITED TO HORIZONTAL AXIS
UPPER PULLEY OFFSET PROVIDES CONSTANT CHAIN GAP
____
X-SYNC™
SRAM X-SYNC™ 1x chain rings provide the highest level of performance and durability. The SRAM X-
SYNC™ tall square teeth edges engage the chain earlier than traditional triangle shaped teeth. The sharp
and narrow tooth profile, as well as rounded chamfer edges, help manage a deflected chain. To provide
the best possible performance in muddy conditions, the X-SYNC™ chainrings have been designed with
mud-clearing recesses for the inner chain links and rollers. Engineered in Germany, X-SYNC™ rings are an
integral part of the SRAM 1x™ drivetrain.
____
X-ACTUATION™
Developed specifically for SRAM 1x™, X-ACTUATION™ keeps shifting sharp and consistent across the
entire cassette.
____
CAGE LOCK™
With CAGE LOCK™ technology in the rear derailleur, wheel removal and installation—as well as chain
installation—becomes faster and simpler. Just pushing the cage forward to create slack and lock it into
place.
____
ROLLER BEARING CLUTCH™ rear derailleurs deliver maximum drivetrain stability—even through the
most punishing terrain. With ROLLER BEARING CLUTCH™ technology, derailleur bounce and chain slap
are eliminated without sacrificing precision.
____
SPEED METAL™
Full metal, 11-speed indexing keeps shifting crisp and precise with Grip Shift.
____
ROLLING THUNDER™
Three rows of ball bearings provide zero friction or play—reducing the force needed to shift and
promoting long-term performance under all weather conditions with Grip Shift.
____
JAWS™
Once the Grip Shift shifter and grip interlock securely, forged aluminum clamps on either end reinforce
the assembly by locking tightly to handlebar.
www.sram.com
