Cane Creek has integrated their Climb Switch into a new coil shock for the public called the DBcoil CS. Already a feature on their Inline and DB Air CS, the Climb Switch gives users a quick way to give the shock a climbing mode that adjusts the rebound and low speed compression with the flick of a switch.
Riders who prefer the linear spring feel and exceptional low speed sensitivity of a coil shock will now have access to a climbing platform. DBcoil CS is the world’s first enduro-specific coil shock for 150-170mm travel bikes with a Climb Switch. (CS). The proprietary CS (patent-pending) feature for Double Barrel shocks adjusts low-speed damping characteristics on-the-fly. Keeping the suspension fully active while you climb results in better connection to the trail and increased efficiency without annoying pedal-bob. When you’re ready to descend, it’s all Double Barrel.
