Lindarets & Wolf Tooth Take to the Road with RoadLink for Wide-Range Shimano Drivetrains
8/5/2015 : sicklines
If you’ve got a road, commuter, or cross bike you’ve been wanting to allow a wide-range casette to work with your ten/eleven speed Shimano drivetrain Lindares and Wolf Tooth have a solution for you.
Introducing the Lindarets x Wolf Tooth RoadLink: Allowing the use of wide-range cassettes with ten- and eleven-speed Shimano road drivetrains.
The US-made RoadLink is an ideal solution for riders looking to convert their road, gravel, ‘cross, or commuter bike to the simplicity and light weight of a single chainring, or for those whose riding demands lower gearing than a typical double can provide.
, Lindarets & Wolf Tooth Take to the Road with RoadLink for Wide-Range Shimano Drivetrains
The RoadLink is optimized for use with ten- or eleven-speed 11-36t and 11-40t cassettes and works great with Wolf Tooth’s 40-tooth Giant Cogs and Drop-Stop chainrings. The RoadLink is compatible with Shimano ten- or eleven-speed road derailleurs and shifters and can be used with single or double chainrings.
The RoadLink is CNC machined from 6061 aluminum, anodized black, and laser etched at Wolf Tooth Components’ Minneapolis facility and comes fitted with stainless steel hardware. The RoadLink installs in moments with little more than a 5mm Allen wrench and a dab of grease.
RoadLinks will be available direct to consumers beginning August 15, 2015 at Lindarets (lindarets.com/roadlink) and Wolf Tooth Components (www.wolftoothcomponents.com/products/roadlink) web stores for $21.95. RoadLinks will be available to shops through select distributors shortly thereafter.
Target Uses:
Single Chainring:
  • Road
  • Cyclocross
  • Commuting
  • Drop-bar mountain
  • Double Chainring:
  • Road
  • Touring
  • Drop-bar mountain
Compatibility:
  • 10s Cassette Compatibility:
  • 11-32: Not Recommended
  • 11-36: Single or Double Chainring
  • 11-40: Single Chainring
  • 11-42: Not Supported
  • 11s Cassette Compatibility:
  • 11-32: Not Required
  • 10-42: Not Supported
  • The RoadLink is compatible with ten- and eleven-speed Shimano road derailleurs and shifters.
  • The RoadLink mounts only to standard derailleur hangers.
  • Double chainrings are only supported with mid- or long-cage rear derailleurs
  • Triple chainrings are not supported.
  • Direct Mount-native frames and SRAM or Campagnolo drivetrains are not supported.
Important Notes:
Due to the lack of a clutch mechanism on Shimano road derailleurs, secondary chain retention (front derailleur or chain device) may be needed, especially for rough- or off-road use.
Due to variations in derailleur hanger geometry, chainstay length, chainring size, B-screw adjustment, and suspension configuration, individual results will vary.
Need More Information?
Please contact [email protected] or [email protected] for additional technical details, explanation, or images.
About Wolf Tooth Components:
Wolf Tooth Components is located in Minneapolis, Minnesota and was founded on strong engineering principles, a love for cycling, and an emphasis on high quality components made in the USA. Riders will find that our products are beautifully machined and provide unparalleled performance
About Lindarets:
Better products, made better. Designed without compromise and built with the industry’s most respected partners, Lindarets products are inspired by big rides and bigger mountains.
Lindarets doesn’t make products that demand the rider’s attention- or attempt to draw that of others. We stay clear of distracting colors, clever slogans, and unnecessary branding. What we do do is deliver the best performance and durability in the world. No questions, no excuses. Guaranteed.
Despite building products in service to play, we take our responsibilities seriously. We recognize and respect our obligation to those who craft our products, the environment from which these products’ materials come, and to the trust that our customers place in us.
