SRAM changed the game with their 1x drivetrain and they continue to deliver new products in this space with the introduction of their GX components with 1x and 2x options. Learn more about SRAM GX inside from SRAM.
GX (RIDE YOUR WAY -FAR AND WIDE)
For every bike, there’s a rider. A rider who builds it. A rider who knows it. A rider who’s always ready to take the bike somewhere new. Introducing GX, the drivetrain for people who love to ride without restraint. From beginner to expert, GX delivers personalized gear choices that take you as far and wide as you want to go. Engineered in Germany with 1x and 2x options, SRAM GX brings the power of riding to everyone, everywhere.
SRAM GX 1×11
Retail : July 2015
GX 1x CRANKSET
The SRAM GX crankset delivers consistent performance every time out. Featuring SRAM’s X-SYNC™ tooth profile, the GX crankset is engineered for complete chain control. Each tooth’s thickness is CNC machined to work seamlessly with the chain’s inner and outer links. And with five available chainrings (30-32-34-36-38), you can personalize your gear range to match the way you ride.
__
FEATURES / BENEFITS
GX 1×11 X-HORIZON™ REAR DERAILLEUR
The SRAM GX X-HORIZON™ rear derailleur is engineered for smooth, reliable shifting action—from the larger upper pulley offset to the 12-tooth X-SYNC™ pulley wheels. By eliminating unwanted chain movement, X-HORIZON™ shifts faster, puts an end to ghost shifting and reduces shift force and chain slap. And with CAGE LOCK™ technology, wheel removal and installation are easier than ever.
GX 11-SPEED TRIGGER SHIFTER
Get sharp, dependable shifting with the SRAM GX X-ACTUATION™ trigger shifter. Built for precise and swift shifting across our wide range 11-speed cassette, the GX trigger shifter brings championship technology to everyone.
__
FEATURES / BENEFITS
GX 11-SPEED GRIP SHIFT
Designed for the most discerning, performance obsessed riders, new GX 11-speed Grip Shift features lightweight construction and delivers outstanding speed and precision.
__
FEATURES / BENEFITS
XG-1150 FULL PIN™ CASSETTE
FULL PIN™ technology uses eleven lightweight, stamped steel cogs held together with 123 high-strength stainless steel pins. The result: a cassette that’s extremely light, durable and equipped with SRAM’s super wide 10-42 gear range that’s a perfect fit for any ride. The open design similar to our X-DOME™ cassette aids in mud clearance, giving you cleaner shifting performance and longer component life.
PC-X1 CHAIN
The recommended chain for GX, PC-X1, comes from a long line of dependable, lightweight chains that are built for toughness. Designed with SRAM’s trusted XX1 geometry, the PC-X1 features solid pin construction, 11-speed PowerLock™ and smooth, efficient shifting that you can count on every time out.
__
FEATURES / BENEFITS
SRAM GX 2×11
Retail : August 2015
Headline 1: RIDE YOUR WAY
With subhead: FAR AND WIDE
Take every ride further with a drivetrain focused on efficiency, durability, and the possibility to go wherever your bike can take you. Introducing GX 2x, simpler than a 3x drivetrain and the widest 2x gear range on the market. Engineered in Germany, GX 2x stands up to every challenge in front of you — from broken pavement to alpine hazards. GX 2x lets you ride as far and wide as your legs will take you.
GX 2×11 CRANKSET
The SRAM GX 2x crankset delivers consistent performance every time out. Featuring SRAM’s X-GLIDE™ chainrings, the GX crankset is engineered for 2x shifting performance. When paired with our wide range 10-42 cassette and GX 2x rear derailleur, GX 2×11 provides the widest range of gears ever offered on a 2x drivetrain.
__
FEATURES / BENEFITS
GX 11-SPEED FRONT DERAILLEUR
The low-profile GX 11-speed front derailleur was designed specifically for SRAM 2×11 X-GLIDE™ shifting. When paired with our wide range 10-42 cassette and GX 2x rear derailleur, GX 2×11 provides the widest range of gears ever offered on a 2x drivetrain. Offered in a wide variety of clamp-mount and direct-mount options.
__
FEATURES / BENEFITS
GX 2×11 REAR DERAILLEUR
Leveraging the legendary history of SRAM shifting, the GX 2×11 rear derailleur provides incredible shifting speed and precision. X-ACTUATION™ technology eliminates slop and shifting variation. ROLLER BEARING CLUTCH™ technology delivers maximum drivetrain stability—even through the most punishing terrain. And with CAGE LOCK™ technology, wheel
__
FEATURES / BENEFITS
GX 2×11 TRIGGER SHIFTERS
Get sharp, dependable shifting with the SRAM GX X-ACTUATION™ trigger shifters. Built for precise and swift shifting across our wide range 11-speed cassette, the GX trigger shifters bring championship technology to everyone.
__
FEATURES / BENEFITS
GX 2×11 GRIP SHIFT
Designed for the most discerning, performance obsessed riders, new GX 2×11 Grip Shift features lightweight construction and delivers outstanding speed and precision.
__
FEATURES / BENEFITS
SRAM GX 2×10
Retail : June 2015
GX 2×10 CRANKSET
The SRAM GX 2x crankset delivers consistent performance every time out. Featuring SRAM’s X-GLIDE™ chainrings, the GX crankset is engineered for 2x shifting performance. Flawless shifting means you’ll never again compromise your speed and power in unpredictable off-road terrain. No more missed shifts, ever. X-GLIDE™ puts you in the right gear, right now.
__
FEATURES / BENEFITS
GX 10-SPEED FRONT DERAILLEUR
The low-profile GX 10-speed front derailleur was designed specifically for SRAM X-GLIDE™ shifting. Flawless shifting means you’ll never again compromise your speed and power in unpredictable off-road terrain. No more missed shifts, ever. X-GLIDE™ puts you in the right gear, right now.
__
FEATURES / BENEFITS
GX 2×10 REAR DERAILLEUR
Leveraging the legendary history of SRAM shifting, the GX 2×10 rear derailleur provides incredible shifting speed and precision. EXACT ACTUATION™ technology eliminates slop and shifting variation. ROLLER BEARING CLUTCH™ technology delivers maximum drivetrain stability—even through the most punishing terrain. And with CAGE LOCK™ technology, wheel removal and installation are easier than ever.
__
FEATURES / BENEFITS
GX 2×10 TRIGGER SHIFTERS
The GX 2×10 trigger shifters feature an aluminum lever, resulting in minimal weight with maximum durability. Pair the GX 2×10 trigger shifters with the MatchMaker™ clamp to streamline your handlebar setup. The GX trigger shifters maintain the legacy of X0 shifting with features and technologies optimized for 2×10 and EXACT ACTUATION™.
__
FEATURES / BENEFITS
2×10 CASSETTES
__
PG-1050
__
PG-1030
TECHNOLOGIES
ALL FOR ONE
SRAM 1x™ is the only one you need: less weight, better chain control and the ability to sync up with any riding style. Our 1x drivetrain philosophy focuses on optimizing how components work together—crank to ring, tooth to chain, shifter to derailleur, derailleur to cassette, and cassette to wheel. No matter where you ride, no matter what you’re up against, SRAM 1x™ takes you further.
X-SYNC™
SRAM X-SYNC™ 1x chainrings provide the highest level of performance and durability. The SRAM X-SYNC™ tall square teeth edges engage the chain earlier than traditional triangle shaped teeth. The sharp and narrow tooth profile, as well as rounded chamfer edges, help manage a deflected chain. To provide the best possible performance in muddy conditions, the X-SYNC™ chainrings have been designed with mud-clearing recesses for the inner chain links and rollers. Engineered in Germany, X-SYNC™ chainrings are an integral part of the SRAM 1x™ drivetrain. Accept no imitation.
X-HORIZON™
This rear derailleur’s “straight parallelogram” design limits all movement to the horizontal axis, which makes ghost shifting impossible while also reducing shift force. For quicker, more exact shifting, the large upper pulley offset design maintains a constant chain gap across all gears.
ROLLER BEARING CLUTCH™ technology eliminates derailleur bounce and chain slap without sacrificing precision.
CAGE LOCK™
With CAGE LOCK™ technology in the rear derailleur, wheel removal and installation— as well as chain installation—becomes faster and simpler. Just push the cage forward to create slack and lock it into place.
X-DOME™
The revolutionary machined design of the X-DOME™ cassette uses the same gruelling manufacturing techniques that produced the PowerDome road cassette. With X-DOME™, ten of the cogs are CNC machined together out of a single block of billet steel, creating an incredibly lightweight, precise and strong cassette.
FULL PIN™
XD™ DRIVER BODY
XD™ is a cassette driver body design that allows the use of a 10-tooth small cog and provides an improved interface with the cassette.
X-ACTUATION™
Developed specifically for SRAM 1x™, X-ACTUATION™ keeps shifting sharp and consistent across the entire 10- to 42-tooth cassette.
SPEED METAL™
Full metal, 11-speed indexing keeps shifting crisp and precise with Grip Shift.
ROLLING THUNDER™
Three rows of ball bearings provide zero friction or play—reducing the force needed to shift and promoting long-term performance under all weather conditions with Grip Shift.
JAWS™
Once the Grip Shift shifter and grip interlock securely, forged aluminum clamps on either end reinforce the assembly by locking tightly to handlebar.
JET™
With durable JET™ black finish, the cassette looks as tough as it performs—ride after ride. JET™ finish provides a higher level of corrosion resistance.
GXP
GXP’s Gutter Seal design cuts friction, durability and weight—improving both feel and performance.
BB30
Besides serious weight savings, this bottom bracket means narrow Q-factor, more ankle clearance, greater bearing durability and stronger crank construction.
_____
SRAM X-SYNC™
A DEVELOPING STORY
MODERN MOUNTAIN BIKERS RIDE HARD, OVER UNPREDICTABLE TERRAIN, IN ALL
KINDS OF CONDITIONS. SO EVERY DETAIL MATTERS.
When SRAM’s engineers first turned their attention to X-SYNC™, they began by examining the multi-speed, single-ring systems that were already on the market. From inside and outside derailment to mud-clogged gear recesses, the rings presented clear opportunities for improvement. So the engineers started to design—and redesign. Each iteration of the new chainring went to the field for trial runs. And from all of this came X-SYNC™, MTB’s first wide tooth, narrow tooth chainring.
But wide tooth, narrow tooth alone didn’t cut it. The SRAM team plowed ahead with a single goal in mind: to create a ring that contributed to the SRAM 1x™ drivetrain built around simplicity and durability. Every detail was scrutinized, leading to optimized square tooth geometry. To asymmetric tooth-tip offset. To sharp-tipped teeth that catch the chain at extreme offsets.
Chamfers and radii designed for optimized guiding. Enhancements engineered to limit roller movement. And mud recesses that keep the chain clean and moving. All focused on the dynamic bike platform for XC, Trail, Enduro, and Gravity riding. And all part of an integrated SRAM 1x™ system precision-designed so that every aspect of X-SYNC™ works perfectly with the rest of the drivetrain.
The original wide tooth, narrow tooth chainring is the optimized ring for riders who never compromise. X-SYNC™—ONLY BY SRAM.
